Driver 430 fails to load on PopOS 20.04 - Hardware failure?
I believe the relevant logs are below, but there is a lot of spam in journalctl:
Jul 06 20:22:51 onyx nvidia-persistenced[6299]: Verbose syslog connection opened
Jul 06 20:22:51 onyx nvidia-persistenced[6299]: Now running with user ID 121 and group ID 128
Jul 06 20:22:51 onyx nvidia-persistenced[6299]: Started (6299)
Jul 06 20:22:51 onyx kernel: NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x25:0x40:1199)
Jul 06 20:22:51 onyx kernel: NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
Jul 06 20:22:51 onyx nvidia-persistenced[6299]: device 0000:01:00.0 - registered
Jul 06 20:22:51 onyx nvidia-persistenced[6299]: Local RPC services initialized
Jul 06 20:22:51 onyx hidpi-daemon.desktop[6291]: ERROR: Unable to load info from any available system
Jul 06 20:22:51 onyx systemd[1]: Started NVIDIA Persistence Daemon.
Jul 06 20:22:51 onyx nvidia-persistenced[6299]: Received signal 15
Jul 06 20:22:51 onyx nvidia-persistenced[6299]: Socket closed.
Jul 06 20:22:51 onyx systemd[1]: Stopping NVIDIA Persistence Daemon...
In particular nvidia-persistenced starting and dying constantly. Including some output from typical debugging commands below:
$ lspci | grep -i nv
01:00.0 VGA compatible controller: NVIDIA Corporation TU106M [GeForce RTX 2070 Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
01:00.2 USB controller: NVIDIA Corporation TU106 USB 3.1 Host Controller (rev a1)
01:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU106 USB Type-C UCSI Controller (rev a1)
70:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
71:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
$ nvidia-smi
No devices were found
Everything was working fine until yesterday - my external displays died and the behavior noted above started. This is relatively new laptop, but I am suspecting a hardware failure. Any way to confirm that?
nvidia-bug-report.sh output: Dropbox - nvidia-bug-report.log.gz - Simplify your life
