Hello support,
Thanks for working so hard on the driver deliveries for linux.
I’ve been trying to make the graphic card work, driver seems to be loaded correctly but the system is not making use of it
Some weeks ago everything was working fine, seems like a recent update broke it.
sudo nvidia-smi
Sat Apr 11 13:40:03 2020
| NVIDIA-SMI 440.82 Driver Version: 440.82 CUDA Version: 10.2 |
| 0 GeForce GTX 1650 Off | 00000000:01:00.0 Off | N/A |
| N/A 45C P8 3W / N/A | 0MiB / 3911MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
*-display
description: VGA compatible controller
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:143 memory:a3000000-a3ffffff memory:90000000-9fffffff memory:a0000000-a1ffffff ioport:4000(size=128) memory:a4000000-a407ffff
*-display
product: UHD Graphics 630 (Mobile)
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:141 memory:a2000000-a2ffffff memory:80000000-8fffffff ioport:5000(size=64) memory:c0000-dffff
nvidia-bug-report.log (311.5 KB)
I hope you guys can help I already tried version 435 440 from the ppa repo, but nothing seems to work, I’m out of ideas.
Thanks in advance
