Since the new driver version 580.159.03, one of my two Tesla P40 doesn’t work as expected. When trying to use it through Docker, it complains about the old driver version (580.142.x) is missing (which makes sense since I’m using the new driver version).
Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: failed to fulfil mount request: open /usr/lib/nvidia/xorg/libglxserver_nvidia.so.580.142: no such file or directory
The other P40 in the same server, on the same vm, works without issue. The only difference is the vbios version. The card that works is on version 86.02.23.00.01 while the broken one is on 86.02.23.00.00.
I see the new driver release note mentions the driver will fail to initialize on VBIOS versions older than 96.00.68.00.xx, so I assume upgrading the vbios won’t hurt and might fix the issue altogether. (plus it has performance improvements).
But I can’t find the firmware upgrade tool for p40 anywhere. Another forum post mentions I should reach out to my vendor, but the vendor is NVIDIA (id 0x10de) and I cant find where to reach out for the tool…
Got any idea of what I can do next? Where I can reach out to get the new firmware version?
nvidia-smi
Sat May 23 19:49:01 2026
| NVIDIA-SMI 580.159.03 Driver Version: 580.159.03 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce GTX 1060 6GB On | 00000000:01:00.0 On | N/A |
nvidia-bug-report.log.gz (3.0 MB)
| 0% 40C P8 6W / 120W | 632MiB / 6144MiB | 20% Default |
| | | N/A |
| 1 Tesla P40 On | 00000000:02:00.0 Off | Off |
| N/A 29C P8 11W / 250W | 1MiB / 24576MiB | 0% Default |
| | | N/A |
| 2 Tesla P40 On | 00000000:03:00.0 Off | Off |
| N/A 29C P8 10W / 125W | 1MiB / 24576MiB | 0% Default |
| | | N/A |
