Driver 580.88 forces TCC mode on L40S / Blackwell GPUs (previously WDDM), causing Isaac Sim to fail
I am experiencing an issue after updating the NVIDIA driver to 580.88 on AWS instances with NVIDIA L40S and Blackwell GPUs.
Environment
  • GPU: NVIDIA L40S (g6e), Blackwell (g7e.4xlarge)
  • OS: Windows Server 2025
  • Driver version: 580.88
  • Platform: AWS EC2
  • Application: NVIDIA Isaac Sim
Problem Description
Initially, using the following AMI:
  • NVIDIA Isaac Sim™ Development Workstation (Windows)
the instance had driver version 582.16 installed by default, and:
  • GPU was in WDDM mode
  • Isaac Sim launched successfully
However, after:
  1. Performing a clean driver installation of version 580.88, or
  2. Installing 580.88 on a fresh Microsoft Windows Server 2025 Base AMI
the GPU consistently switches to:
Driver Model: TCC
Attempts to switch back to WDDM:
nvidia-smi -g 0 -dm 0
result in:
Not Supported
Additional Findings
  • The same behavior occurs on:
    • g6e.4xlarge (L40S)
    • g7e.4xlarge (Blackwell)
  • In all cases:
    • Default (582.16) → WDDM
    • After installing 580.88 → TCC (locked)
Impact
  • Isaac Sim fails to launch when GPU is in TCC mode
  • No way to switch back to WDDM
  • Reproducible across multiple instance types and AMIs
Questions
  1. Is TCC-only behavior expected in driver 580.88 for L40S and Blackwell GPUs?
  2. Has WDDM support been restricted or removed in this driver version?
  3. Why does the preinstalled driver (582.16) support WDDM while 580.88 does not?
  4. Is there a supported method to enable WDDM mode on these GPUs?
  5. Which driver versions are recommended for Isaac Sim on Windows Server 2025?
Summary
  • WDDM works on preinstalled driver (582.16)
  • WDDM becomes unavailable after installing 580.88
  • Issue reproduced across multiple GPU generations and AMIs
Any guidance would be greatly appreciated.
Thank you.
