Driver 595.71: OMM validation is broken
I recently updated the driver to 595.71.
Originally I noticed that a sample program with OMM in my OptiX wrapper library fails to build a GAS when enabling the OptiX validation.
Then, I tried optixOpacityMicromap sample in the SDK with validation (I needed to modify the code a bit to always enable validation since DEBUG definition is not active in Windows even in debug build)
I got the following message and the program crashes:
[ 2][VALIDATION_ERROR]: [OMM_USAGE_COUNTS_MISMATCH] App-supplied OMM usage count histogram does not match the OMMs found in build inputs. Either: 1) Per-OMM entries in an OMM array build do not add up to the histogram, or 2) OMMs linked to triangles in a BLAS build do not add up to per-geometry histograms
    geometry index: 0
    OMM format: OC1_2_STATE
    OMM subdivision level: 0
    count in histogram: 32
    count in build inputs: 0
    current operation:
        type: build
        object type: BLAS
        object address: 0x130da01400
Thanks,
My environment:
OptiX 9.1
13.1
Driver: 595.71
Geforce RTX 4080
Visuals Studio 2022 17.14.27
Windows 11 Pro 25H2 26200.7922
Confirming this is broken for me too. We’re looking into it, and into why we didn’t catch it. Thank you for the report! I’ll post more info if I hear about any workarounds.
David.
Same here on D3D12, using NVAPI. The validation layers return completely wrong histogram values : 2 state instead of 4 state, unusually high count in build inputs, or invalid subdivision level. I do not know what’s the result on the DXR version however.
We have a fix in the works for a future driver version. It might not make the very next driver release, but will at least be fixed in the one after that. Again, thank you for reporting this.
David.
