I defined a texture reference as follows:
static texture<unsigned char, 2, cudaReadModeNormalizedFloat> tex;
and I’d like to bind a CUarray to the texture reference using the driver API:
CUtexref texref;
CU_SAFE_CALL(cuModuleGetTexRef(&texref, module, "tex"));
CU_SAFE_CALL(cuTexRefSetArray(texref, cuarray, CU_TRSA_OVERRIDE_FORMAT));
CU_SAFE_CALL(cuTexRefSetAddressMode(texref, 0, CU_TR_ADDRESS_MODE_WRAP));
CU_SAFE_CALL(cuTexRefSetAddressMode(texref, 1, CU_TR_ADDRESS_MODE_WRAP));
CU_SAFE_CALL(cuTexRefSetFilterMode(texref, CU_TR_FILTER_MODE_POINT));
CU_SAFE_CALL(cuTexRefSetFlags(texref, CU_TRSF_READ_AS_INTEGER));
CU_SAFE_CALL(cuTexRefSetFormat(texref, CU_AD_FORMAT_UNSIGNED_INT8, 1));
cuarray is a CUarray with format CU_AD_FORMAT_UNSIGNED_INT8.
However in my kernel the texfetches doesn’t return anything. It works only if I use cudaReadElementType instead of cudaReadModeNormalizedFloat or when using the runtime API to bind an array to the texture reference.
What am I doing wrong?
