Hello there,
I have a weird problem with kernel parameters.
Here’s the kernel prototype :
__global__ void projPlanGPU_kernel(float * gOut,
float dt,
float2 dtache,
unsigned int wima,
unsigned int hima)
I’m setting the parameters this way :
int offset = 0;
void* ptr = (void*)(size_t)d_output;
ALIGN_UP(offset, __alignof(ptr));
cuParamSetv(projPlanGPU, offset, &ptr, sizeof(ptr));
offset += sizeof(ptr);
ALIGN_UP(offset, __alignof(dt));
cuParamSetf(projPlanGPU, offset, dt);
offset += sizeof(dt);
ALIGN_UP(offset, 8);
cuParamSetv(projPlanGPU, offset, &dtache, sizeof(dtache));
offset += sizeof(dtache);
ALIGN_UP(offset, __alignof(wima));
cuParamSeti(projPlanGPU, offset, wima);
offset += sizeof(wima);
ALIGN_UP(offset, __alignof(hima));
cuParamSeti(projPlanGPU, offset, hima);
offset += sizeof(hima);
cuParamSetSize( projPlanGPU, offset );
In this configuration, i have an error after kernel launch when i do a cuCtxSynchronize().
1 - If i remove ‘dtache’ parameter, i get the same error.
2 - If i remove ‘dt’ parameter, i don’t have the error anymore.
At the begining i thought of a maximum number or size for parameters, but it seems i’m far from it (256 bytes). Moreover i’m surprised by the behaviour when i remove one parameter…
Any idea would be of great help because i cannot see where i missed a thing !
Thanks in advance =)
While writing the post i thought of an alignment problem… And actually, if my offset is modulo 8, everything’s running fine. When i’m modulo 4, i get the error.
Maybe i missed a thing in programming guide, but i still wanted to post my problem just in case someone have the same.
Problem resovled then, but still, if anyone can confirm this behaviour, i’d be interested !
Thanks again !
