The texture is declared like this and is of size 4 x4
texture<uint8_t, 2, cudaReadModeElementType> refTex;
I set the following texture parameters
// set texture parameters
CUtexref cu_texref;
errorCode= (cuModuleGetTexRef(&cu_texref, cuModule, "refTex"));
cuErr(errorCode, "Fetching reference to global texture failed");
errorCode= (cuTexRefSetArray(cu_texref, cu_array, CU_TRSA_OVERRIDE_FORMAT));
cuErr(errorCode, "Set CUDA array format failed");
errorCode= (cuTexRefSetAddressMode(cu_texref, 0, CU_TR_ADDRESS_MODE_WRAP));
cuErr(errorCode, "Set CUDA addressing mode failed");
errorCode= (cuTexRefSetAddressMode(cu_texref, 1, CU_TR_ADDRESS_MODE_WRAP));
errorCode= (cuTexRefSetFilterMode(cu_texref, CU_TR_FILTER_MODE_POINT));
// errorCode= (cuTexRefSetFilterMode(cu_texref, CU_TR_FILTER_MODE_LINEAR));
cuErr(errorCode, "Set CUDA filtering mode failed");
//if(NORMALIZED)
errorCode= (cuTexRefSetFlags(cu_texref, CU_TRSF_READ_AS_INTEGER));
cuErr(errorCode, "Set CUDA normalized coordinate addressing mode failed");
errorCode= (cuTexRefSetFlags(cu_texref, CU_TRSF_NORMALIZED_COORDINATES));
// else
errorCode= (cuTexRefSetFormat(cu_texref, CU_AD_FORMAT_UNSIGNED_INT8, 1));
cuErr(errorCode, "Set CUDA texture data type failed");
CUfunction hfunc;
//CUresult cuModuleGetFunction ( hfunc, CUmodule hmod, const char* name )
errorCode = cuModuleGetFunction( &hfunc, cuModule, "Png_kernel" );
cuErr(errorCode, "Get module functionPNG_TEXTURE failed");
errorCode= cuParamSetTexRef(hfunc, CU_PARAM_TR_DEFAULT, cu_texref);
cuErr(errorCode, "Bind CUDA array totexture failed");
When I use normalized coordinates the texture fetch gives invalid values
__device__
uint8_t ditherTex ( uint32_t x, uint32_t y,uint8_t ditherFactor)
float u,v;
float spacing =(1.0/(float)ditherFactor);
float midpoint = 0.5;///(float)ditherFactor;
u= ((float)x+ midpoint)*spacing;
v= ((float)y+ midpoint)*spacing;
return tex2D(refTex,u,v);
But when I turn of normalized coordinates the texture fetch works properly
When I use no unnormalized coordinates the kernel reads properly the texture
__device__
u= x%ditherFactor;
v= y%ditherFactor;
return tex2D(refTex,u+0.5,v+0.5);
My goal is to paste the small 4 by 4 texture into a 2000 x 2000 image. In the context of unnormalized coordinates I use the modulo operator to imitate the WRAP mode which works just fine. But when i switch to normalized coordinates the texture fectch returns invalid values.
Thanks for your help
nicolas
