During initialization, my application creates a buffer view with 0x940b90 elements of type VK_FORMAT_R32G32B32A32_SFLOAT
Here is the output from the api_dump layer, for reference:
t{0} vkCreateBufferView(device = 0x2f2a980, pCreateInfo = 0x1bf2c8, pAllocator = 0x0, *pView = 0x59af150) = VK_ERROR_VALIDATION_FAILED_EXT
pCreateInfo:
sType = VK_STRUCTURE_TYPE_BUFFER_VIEW_CREATE_INFO
pNext = 0x0
flags = 0x0
buffer = 0x5a4dc50
format = VK_FORMAT_R32G32B32A32_SFLOAT
offset = 0x0
range = 0x940b900
But when vkCreateBufferView
is executed, it returns VK_ERROR_VALIDATION_FAILED_EXT
and the driver outputs this on the debug callback:
vkCreateBufferView: pCreateInfo->range 940b900 is too big for the texel buffer maximum 8000000
As far as I know, the only limit in Vulkan related to buffer views is maxTexelBufferElements
, which is 0x8000000 for my GTX 970. But note that this is defined as the limit to the number of elements of a buffer view, and not a limit to the size in bytes as the driver seems to think. Therefore the error returned by the driver is wrong.
Drivers version: 373.06
Hardware: GTX 970
OS: Windows 7 64bits
