The ‘system’->‘administration’->‘display’->‘display settings’ listed ALL resolutions that the video card and monitor support.
The ‘system’->‘preferences’->‘screen resolution’ only listed PART of them without the high resolution listed.
This link explained it and provided the solution for changing the display resolutions:
It needs “driver” to replace “vesa”
Found driver from NVIDIA by running the utility called NVchooser.sh obtained from there. It suggested the right drivers: NVIDIA_kernel-1.0-4191.src.rpm and NVIDIA_GLX-1.0-4191.i386.rpm
However, when “rpmbuild --rebuild NVIDIA_kernel-1.0-4191.src.rpm” it complains:
“Legacy syntax is unsupported: copyright”
“Line 15: Unknown tag: Copyright: NVIDIA Corp. 2000”
Please help to get around with the copyright issue!
birdie is right, you shouldn’t be using 4191. Please see the sticky post with the title Current graphics driver releases for information on which driver you need.
