I’m using the nvidia driver only to speed up my KDE plasma desktop environment, not for gaming or deep learning. Every couple of days I’m running into severe issues. Although they are slightly different, I post them in the same thread because I assume (and hope) they share a common reason.
- Extremely loud fan noise of the graphics card
- KDE Plasma suddenly becomes slow, but does not become unusable.
- KDE Plasma gradually becomes extremely slow, reacts only every couple of minutes (!) to a mouse click. I invested 2 hours to create the attached log file.
In all three cases nvidia-smi confirms there is a problem. Example:
| NVIDIA-SMI 520.56.06 Driver Version: 520.56.06 CUDA Version: 11.8 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
|ERR! 69C P0 ERR! / 130W | 2379MiB / 6144MiB | 0% Default |
| | | N/A |
I attached log files for all the three cases I described (in the single zip file). In addition to 520.56.06 I also tried 515.76 and 470.141.03. With all three versions, above problems occur, but with 470.141.03 they happen more frequently (several times a day).
Directly after booting, nvidia-smi confirms that everything is okay, and I can run Unigine_Valley-1.0 with excellent frame rate (with 470, it is better than with no driver, but far worse than with 515 or 520). A summary of my system:
Computer model: Micro-Star International Co., Ltd. MS-7D42/MAG Z690M MORTAR WIFI (MS-7D42), BIOS B.91 10/17/2022
CPU: 12th Gen Intel(R) Core(TM) i9-12900T
Physical cores: 16
Graphics card: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
Total RAM: 125 GB
Linux distribution: Feren OS
Ubuntu codename: focal
Debian version: bullseye/sid
Linux kernel version: 5.15.0-56-generic
One last information: nvidia-smi seems to cause above issues. I am not sure about this, but when calling it directly after booting (when everything is still okay), I have the feeling that the issues occur more frequent than usual. Of course, for the cases in the log files, I only executed nvidia-smi after the issue arose.
nvidia-bug-reports.log.gz (1.8 MB)
