jas-mx
August 27, 2019, 9:00am
1
We are making a available a driver for the RPI v1.3 camera (and clones). This is a an alpha release so there may be limitations or bugs. I have created a pre-compiled kernel/dtb for deployment against LT4 R32.2 and instructions are covered here for anyone who wants to test.
Supported resolutions are:
2592 x 1944 @15 fps
1920 x 1080 @30 fps
1280 x 960 @45 fps
1280 x 720 @60 fps
Feedback welcome.
snarky
August 28, 2019, 5:08am
3
Pff! Everybody knows that the GPL isn’t legally binding if you’re on the internet!
jocover
September 2, 2019, 11:42am
4
great work
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, ov5647 6-0036
Bus info : platform:54080000.vi:0
Driver version: 4.9.140
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: no power)
Format Video Capture:
Width/Height : 1280/720
Pixel Format : 'BG10'
Field : None
Bytes per Line : 2560
Size Image : 1843200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
group_hold 0x009a2003 (bool) : default=0 value=0 flags=execute-on-write
sensor_mode 0x009a2008 (int64) : min=0 max=0 step=0 default=0 value=3 flags=slider
gain 0x009a2009 (int64) : min=0 max=0 step=0 default=0 value=128 flags=slider
exposure 0x009a200a (int64) : min=0 max=0 step=0 default=0 value=9999 flags=slider
frame_rate 0x009a200b (int64) : min=0 max=0 step=0 default=0 value=60000000 flags=slider
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=1
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=1
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
write_isp_format 0x009a2068 (bool) : default=0 value=0
sensor_signal_properties 0x009a2069 (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=4 flags=read-only
