Dear Nvidia-team,
I have a MacbookPro 2015 with ElementaryOS on an thunderbolt jetdrive and a Razor Core X with RTX3070 installed on another thunderbolt port. I want to use a 5k Monitor via DP->thunderbolt cable. I tried a lot to install the latest NVIDIA driver 455 using the NVIDIA installer script, apt, and also Ubuntu ‘additional driver’ software. Still the driver doesn’t work.
After reboot when the eGPU is connected from the beginning to the thunderbolt port the internal screen stays black. When booting without the eGPU connected, I can boot normally. When connecting the eGPU I get:
dmesg | grep -i nvidia
[ 36.687431] nvidiafb 0000:3c:00.0: enabling device (0000 → 0003)
[ 36.687524] nvidiafb: Device ID: 10de2484
[ 36.687525] nvidiafb: unknown NV_ARCH
[ 36.978490] nvidia: loading out-of-tree module taints kernel.
[ 36.978527] nvidia: module license ‘NVIDIA’ taints kernel.
[ 36.986017] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 36.992981] nvidia-nvlink: Nvlink Core is being initialized, major device number 236
[ 36.993567] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 36.993710] nvidia: probe of 0000:3c:00.0 failed with error -1
[ 36.993724] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 36.993725] NVRM: None of the NVIDIA devices were initialized.
[ 36.994012] nvidia-nvlink: Unregistered the Nvlink Core, major device number 236
[ 37.362603] nvidia-nvlink: Nvlink Core is being initialized, major device number 236
[ 37.363441] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 37.363581] nvidia: probe of 0000:3c:00.0 failed with error -1
and
lspci -vv | grep -i -A11 nvidia
3c:00.0 VGA compatible controller: NVIDIA Corporation Device 2484 (rev a1) (prog-if 00 [VGA controller])
Subsystem: Gigabyte Technology Co., Ltd Device 404c
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 19
Region 0: Memory at a5000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at (64-bit, prefetchable)
Region 3: Memory at (64-bit, prefetchable)
Region 5: I/O ports at 5000 [size=128]
[virtual] Expansion ROM at a6000000 [disabled] [size=512K]
Capabilities:
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
3c:00.1 Audio device: NVIDIA Corporation Device 228b (rev a1)
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
Interrupt: pin B routed to IRQ 16
Region 0: Memory at a6080000 (32-bit, non-prefetchable) [size=16K]
Capabilities:
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
I have followed some webpages to get rid of the nouveau, but without success.
Hopefully the bug report helps you understand what is the problem.
All the best,
Florian
nvidia-bug-report.log.gz (607.6 KB)
nvidia-installer.log (28.7 KB)
