I just installed the developer driver for CUDA 4.1 (285.05.33) on a fresh install of Ubuntu 11.04, which is listed as the officially supported version. I then rebooted and found my computer was mostly dead. More specifically, X can’t start, saying there’s an API mismatch between the NVIDIA kernel module and the NVIDIA driver.
What do I need to do to bring my computer back to life?
I have optimus on a laptop with Ubuntu 11.10. I installed bumblebee for the optimus and then I installed the toolkit and the example. You need gcc-4.4 and g+±4.4. Also ther are some symbolic links you need to take care.
Unfortunately it is really tedious, I reinstall Ubuntu 6-8 times before I figured out how to do it. With bumblebee you get the to run the cuda programs like you would run the games with optimus and it has a nvidia driver compatible with cudatoolkit 4.1. I do no see other way because of the way the optimus works.
If you have grub, add to the line from which you boot, ’ text nomodeset ', it will bring you to text mode without X. Then uninstall the current nvidia driver (probably some different driver was installed upon Ubuntu installation) and install the current 4.1 again.
Hi, I’ve tryed to follow this instructions, all seems to work correctly … but when I try to compile an SDK code (e.g. deviceQuery) it turns out “/usr/bin/ld: cannot find -lcuda”
in a PC where CUDA works, in the folder /usr/lib, i have the files libcuda.so, libcuda.so.1 and libcuda.so.285.05.33, but in the PC with optimus i haven’t these files.
But I can’t run CUDA programs. (I can’t even compile them, because the OpenGL headers don’t seem to have been installed. My research indicates those are supposed to come with the video driver?)
As far as I can tell (and I could easily be wrong about this), the problem is that the video driver and the CUDA developer driver need to be compatible with each other. And they aren’t. The video driver installed by apt-get is 270.41.06. If I go to the NVIDIA website (http://www.nvidia.com/Download/index.aspx?lang=en-us), it offers a newer driver: 295.20. But if I go to the CUDA 4.1 download page (http://developer.nvidia.com/cuda-toolkit-41), the developer drivers have still a different version number, which is incompatible with both of the above: 285.05.33. This is despite the fact that it claims to work with Ubuntu 11.04.
What set of drivers do I actually need to install to get CUDA working?
Then I ran the CUDA 4.1 driver installer (285.05.33). Part way through installing, it gave me a long string of error messages about “Cannot create file” and “Cannot restore file”. The files all seemed to relate to the earlier driver (270.41.06). I held down the enter key, and eventually the error messages stopped appearing. It then claimed to have successfully installed the driver.
I rebooted. It got as far as the point where X starts up, and then the screen filled with garbage. It appears to be completely frozen. For example, ctrl-alt-f2 does nothing.
Any suggestions? (I can still boot into recovery mode, so I can at least get to a command prompt.)
It’s a desktop (Dell XPS) with a GTX 580. I installed Ubuntu 11.04 from the live CD, telling it to reformat the partition. After installing, I ran software update to make sure everything was up to date, then installed the NVIDIA driver and CUDA toolkit from the CUDA 4.1 download page. I rebooted, and found that X was dead. It was at that point that I posted here. I had installed no other software on the system: it was a completely clean install.
One of my coworkers managed to get it working. The actual problem was a conflict between the NVIDIA driver and the Nouveau driver which apparently is preinstalled on Ubuntu. He managed to disable Nouveau - I’m not sure of the details of precisely how - and now it works.
This is pretty clearly a bug in the NVIDIA installer. It was run on a completely clean installation of the precise version of Ubuntu it’s advertised to work with, so there’s no legitimate reason for it to conflict with anything.
