Currently, all of the components listed above are connected but we are not able to see any feed from the cameras and suspect this is a driver issue. We are looking for a driver, or a modifiable template, which supports the communication between camera stream and the Jetson Xavier.
Has anyone worked with this hardware, or run into a similar situation?
We would also appreciate any guidance you may have about how we may approach this problem.
@wearedesertwave@ShaneCCC
Unfortunately, we don’t have driver for Jetson Xavier NX Developer kit, but we have IMX274-MIPI driver for our own NX carrier board and can provide the source code for reference if needed.
@SimonZhu
Thank you very much for the assistance! If you were in my shoes would it be possible to modify the driver for the MX274-MIPI-M12 version based on the driver you are referencing?
If anything, I would appreciate the MX274-MIPI driver for reference. We will credit anything that we modify in our technical writing.
@ShaneCCC
I am unsure what you mean by L4T, what is this referring to?
@wearedesertwave
If your team have experience on Linux driver development, it should be easy for you to build this driver.
You can download the patch files from link below and apply it to L4T 32.5.0 kernel code.
The L4T 32.5.0 kernel code can be download from Nvidia website or link below.
Alternatively, we can also provide custom driver services to customer. You can contact support@leopardimaging.com if you would like to have a NRE project.
