I have a custom carrier board for TX1 that I am using. Whenever I try to load any SPI drivers I see the following msgs in dmesg output.
Using the same TX1 on the Jetson carrier board, loading the same SPI driver I don’t see this. I’m guessing it’s something to do with the way the carrier board powers the TX1. Any ideas what the error is indicating?
The TX1 doesn’t misbehave in any manner, and things seem to be working fine.
Hi notthetup
Suppose this customize carry board didn’t design a PMIC to control the power on/off. If the power are always supply that could be a warning message and harmless.
I’m still having this issue. In fact this message is occurring in kern.log and syslog something like 500 times per second, causing syslog and kern.log to produce around 700MB/hour (duplicated in syslog and kern.log). I’ve set up logrotate to process every hour but I still frequently get disk full errors and I’m taking a performance hit.
We have 4 USB3.0 Point Grey Blackfly cameras connected via a power USB3 hub. We’re using the Connecttech Astro carrier board with the stock nvidia Jetpack 2.3, but I’ve seen the same behavior with JP 3.0. We’re seeing identical behavior on 4 different identical setups.
I tried installing Jetpack 3.1 (L4T 28.1) and on first look that seems to have gotten rid of the voltage warnings, but I’ll continue to monitor things over the next few days.
I have success connect my hitachi camera via USB3.0 on jetsontx1 developement kit.
I can get video, control camera with uart via USB3.0 port.
But when i tried to use J100 carrier boards, there’s a bunch of error appear in dmesg output.
Camera still controlled with uart but video was not received.
[ 983.803982] usb 2-2: new SuperSpeed USB device number 4 using tegra-xhci
[ 983.828675] usb 2-2: New USB device found, idVendor=04b4, idProduct=00f9
[ 983.828806] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 983.828893] usb 2-2: Product: TWIGACam
[ 983.828964] usb 2-2: Manufacturer: Twiga
[ 984.835977] uvcvideo: Found UVC 1.10 device TWIGACam (04b4:00f9)
[ 984.864135] input: TWIGACam as /devices/platform/tegra-xhci/usb2/2-2/2-2:1.0/input/input3
[ 984.865648] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 984.866169] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.867454] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.868396] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.869290] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.870176] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.871061] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.871933] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.873132] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.874001] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[ 984.874223] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.875420] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.876642] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.877476] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 984.877668] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.877736] cdc_acm 2-2:1.2: This device cannot do calls on its own. It is not a modem.
[ 984.878629] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.879517] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.880399] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.881270] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.883070] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.884040] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.884927] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.885683] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[ 984.885847] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.887121] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.887812] cdc_acm: probe of 2-2:1.2 failed with error -22
[ 984.888124] usbserial_generic 2-2:1.2: Generic device with no bulk out, not allowed.
[ 984.896753] usbserial_generic: probe of 2-2:1.2 failed with error -5
[ 984.897463] usbserial_generic 2-2:1.3: The "generic" usb-serial driver is only for testing and one-off prototypes.
[ 984.897492] usbserial_generic 2-2:1.3: Tell linux-usb@vger.kernel.org to add your device to a proper driver.
[ 984.897516] usbserial_generic 2-2:1.3: generic converter detected
[ 984.898185] usb 2-2: generic converter now attached to ttyUSB0
[ 984.898712] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.899395] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 984.899522] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.900168] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.900787] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.901387] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.901989] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.902736] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.903518] platform cc.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.904222] platform cd.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.904781] reg-fixed-sync-voltage ce.regulator: Consumer c0 does not have device name
[ 984.904917] platform ce.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.905575] platform d1.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.906228] platform d3.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.906786] reg-fixed-sync-voltage 5.regulator: Consumer c1 does not have device name
[ 984.906930] platform 5.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.907591] platform 7.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.908237] platform d.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.908877] platform c9.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.909575] platform ca.regulator: Driver reg-fixed-sync-voltage requests probe deferral
[ 984.910257] platform cb.regulator: Driver reg-fixed-sync-voltage requests probe deferral
Please help me to solve this. I’m using JetsonTX1 on J100 carrier board with Jetpack 3.0 installed.
Have you contacted with Auvidea?
Or you could try to update with their latest firmware to see if the problem still existing?
[url]https://auvidea.com/firmware/[/url]
I have tried both firmwares 2.2 and 2.3 in https://auvidea.com/firmware/ in both L4T24 and L4T28 and I still have the same problem. Does anyone found the solution to the problem? I am using the carrier board J120.
