Hi all,
I am trying make 10X10 matrix of floats in GPU and trying to do memcpy2D to GPU from a linear array of 400 bytes
I am getting seg fault from " in pthread_attr_setdetachstate () from /usr/lib64/libcuda.so.1" from cud lib .I am exactly following the Nvidia cuda programming guide. I try to change pcopy.WidthInBytes=40;
pcopy.Height=10 to test what is causing it.
Can anyone shed some light on this please??
Regards and thanks
more_ more_parallel
I am passing the code for your verification.
iint main()
void *pp;
unsigned int msize=0;
CUdevice dev;
CUcontext ct;
CUresult res;
cuInit(0);
if((cuDeviceGet (&dev,0))!=CUDA_SUCCESS)
std::cout<< "error in device get"<<std::endl;
res=cuCtxCreate (&ct,0,dev);
if(res!=CUDA_SUCCESS)
std::cout<< "error in context creation "<<res<<std::endl;
void *p2DArray;
CUarray a1;
CUdeviceptr Hdptr;
CUDA_MEMCPY2D pcopy;
CUDA_ARRAY_DESCRIPTOR desc;
desc.Format = CU_AD_FORMAT_FLOAT;
desc.NumChannels = 1;
desc.Width = 10;
desc.Height = 10;
res=cuMemAllocHost (&p2DArray,400);
std::cout<< "error in MemAlloc"<<res<<std::endl;
res=cuArrayCreate(&a1,&desc);
std::cout<< "error in ArrayCreate"<<res<<std::endl;
pcopy.srcMemoryType = CU_MEMORYTYPE_HOST;
pcopy.srcHost=p2DArray;
pcopy.srcPitch=400;
pcopy.dstMemoryType = CU_MEMORYTYPE_ARRAY;
pcopy.dstArray=a1;
pcopy.Height=10;
res=cuMemcpy2D(&pcopy);
std::cout<< "error in copy2d array "<<res<<std::endl;
