I’m facing an issue that, there were no additional drivers available in software & updates tab, how to get additional drivers
Could anyone tell me how can i install all the supported drivers
Attaching image for your reference
Dear @sudhirkumar.avv nvidia-smi is not available on DRIVEOS target. From logs, It appears that you are asking about Ubuntu host and not target.
Are you looking to install NVIDIA drivers? If so, Do you plan to run any DW/CUDA/TRT sample on host? May I know which GPU is available on host?
If you are just looking to develop the application in host and cross compile to run on target, then you can use DRIVE OS cross compiling toolchain for. You may also use DRIVE OS 6.0.8.1 docker container for application development and flashing target. Using docker avoids all issues related to host environment.
If you plan to docker, please check Install DRIVE OS 6.0.8.1 for NVIDIA Developer Users | NVIDIA Docs
