Driveworks gps logger doesn t work with GPS mouse
Hi there!
I have a u blox EVK-ML8 and a navilock NL-8012U. Both are GPS mouse connected via USB and I would like to get the gps logger running with it.
When I start the logger I’m stuck after:
nvidia@nvidia:/usr/local/driveworks/bin$ ./sample_imu_logger --driver=imu.uart --params=device=/dev/ttyACM0,baud=9600
Initialize DriveWorks SDK v0.6.67
Release build with GNU 4.9.2 from v0.6.0-rc7-0-g51bd3aa against Vibrante PDK v5.0.5.0
TimeSource: monotonic epoch time offset is 1534379754218388
TimeSource: PTP ioctl returned error. Synchronized time will not be available.
TimeSource: Could not detect valid PTP time source at 'eth0'. Fallback to CLOCK_MONOTONIC.
SDK: Resources mounted from /usr/local/driveworks-0.6/data/resources
nvrm_gpu: Bug 200215060 workaround enabled.
SDK: Create NvMediaDevice
egl::Display: found 2 EGL devices
egl::Display: use drm device: drm-nvdc
SDK: number of GPU devices detected 2
SDK: currently selected GPU device discrete ID 0
SAL: identified board as DrivePX2-TegraA
SensorFactory::createSensor() -> imu.uart, device=/dev/ttyACM0,baud=9600
EndpointTTY: started on /dev/ttyACM0
I have tried the IMU and GPS logger and bother provide the same result…
When I try:
sudo stty -F /dev/ttyACM0 raw -echo -echoe -echok
sudo cat /dev/ttyACM0
then I get this:
$GNGLL,3723.08308,N,12154.89100,W,010917.00,A,D*6B
$GNRMC,010918.00,A,3723.08304,N,12154.89103,W,0.067,,160818,13.17,E,D*1A
$GNVTG,,T,,M,0.067,N,0.125,K,D*3F
$GNGGA,010918.00,3723.08304,N,12154.89103,W,2,12,0.75,18.3,M,-29.8,M,,0000*4D
$GNGSA,A,3,10,32,20,27,21,14,08,24,48,51,,,1.58,0.75,1.39*1E
$GNGSA,A,3,82,67,68,83,81,66,,,,,,,1.58,0.75,1.39*1E
$GPGSV,4,1,13,08,34,299,37,10,67,007,45,11,00,316,,14,38,200,37*7D
$GPGSV,4,2,13,15,03,044,17,18,11,310,19,20,49,057,37,21,39,123,36*7A
$GPGSV,4,3,13,24,18,063,19,27,49,254,27,32,63,191,26,48,45,198,35*72
$GPGSV,4,4,13,51,44,157,35*4A
$GLGSV,3,1,09,66,17,042,14,67,62,002,40,68,43,257,29,75,00,014,*6D
$GLGSV,3,2,09,76,07,055,,77,00,108,,81,25,160,35,82,75,192,27*6A
$GLGSV,3,3,09,83,44,325,20*51
$GNGLL,3723.08304,N,12154.89103,W,010918.00,A,D*6B
$GNRMC,010919.00,A,3723.08302,N,12154.89104,W,0.036,,160818,13.17,E,D*1E
$GNVTG,,T,,M,0.036,N,0.066,K,D*3D
$GNGGA,010919.00,3723.08302,N,12154.89104,W,2,12,0.75,18.2,M,-29.8,M,,0000*4C
$GPGSV,4,2,13,15,03,044,16,18,11,310,18,20,49,057,37,21,39,123,36*7A
$GPGSV,4,3,13,24,18,063,19,27,49,253,27,32,63,191,26,48,45,198,35*75
$GNGLL,3723.08302,N,12154.89104,W,010919.00,A,D*6B
$GNRMC,010920.00,A,3723.08301,N,12154.89105,W,0.018,,160818,13.17,E,D*1A
$GNVTG,,T,,M,0.018,N,0.033,K,D*31
$GNGGA,010920.00,3723.08301,N,12154.89105,W,2,12,0.75,18.1,M,-29.8,M,,0000*47
$GPGSV,4,2,13,15,03,044,16,18,11,310,20,20,49,057,37,21,39,123,36*71
$GPGSV,4,3,13,24,18,063,18,27,49,253,27,32,63,191,26,48,45,198,35*74
$GLGSV,3,3,09,83,44,325,21*50
which according to the documentation would mean that it works~
Can someone give me some help here please?
Do you know which specific NMEA message driveworks is looking for? (I couldn’t find it by looking into the code)
As a side comment I can get xgps to work fine!
If I run the pre recorder checker the GPS sensor is receiving some information:
SDK: Release NvMediaDevice
Driveworks SDK released
Report of 5000(ms) monitoring:
Sensor camera:
channel 0: frame read = 146, frame rate = 29.2(fps)
Sensor gps:
channel 0: data read = 5916, data rate = 1183.2(B/s)
Result: ok
when I start the recorder I’m told Wait For GPS…
If someone has an idea that would be great!
thank you very much for your support!!!
Dear jdahan26,
Have you checked this sample with USB option like --params=device=/dev/ttyUSB0? Thanks.
There is no part of specific NMEA message in DW. Please refer to the following link for that part.
http://gpsworld.com/what-exactly-is-gps-nmea-data/
Hi Steve!
sorry for the delay we had some network issues! Thanks for your reply and unfortunately if I use ttyUSB0 that doesn’t work… Only ttyACM0 works!
Which GPS USB mouse do you usually use?
thank you for your support!
