I can see only the includes file inside driveworksamples/dw_includes, If I want to use the function inside the header files I need libraries also, someone please let me know the library path.
Abhi
Abhi
Dear abhilash,
You can find shared libraries at <Driveworks_path>/lib (Ex:/usr/local/driveworks-1.2/lib)
Thanks Sivaramakrishna for you reply.
Do we have equivalent libraries which can work in Linux machines… ?
Yes. You can find at same path on your host machine.
Thanks you. I will check it out
Hi Sivaramakrishna,
I need one more clarification, can you please let me know the path for “Building for the Linux Host System” file
in driveworks setup…
Dear Abhilash,
If you are asking for building samples on linux, please check file:///usr/local/driveworks-/doc/nvdwx_html/dwx_samples_building.html
