Driveworks not installing
I did as the below guideline.
https://docs.nvidia.com/drive/driveinstall_docs/#developertools/mobile/driveinstall/linux/5.0.5.0b/sdk/install.htm%3FTocPath%3D_____3
but failed to install driveworks, there is no folder driveworks upder /usr/local
the install log file( driveworks_target.log ) content :
“Installing DriveWorks debs …
Done.”
why I can’t install driveworks on target with DriveInstall?
the other software eg. cuda9.0 can be installed on target properly.
but Driveworks cannot be Installed.
root 25283 0.0 0.0 198516 4832 ? Ssl 19:32 0:00 /home/shane/NVIDIA/Drive/5050bL_SDK/_installer/sudo_daemon -installer=25233 -d=/home/shane/NVIDIA/Drive/5050bL_SDK/_installer/tmp
0
/home/shane/NVIDIA/Drive/5050bL_SDK///_installer/run_command -c=“cd /home/shane/NVIDIA/Drive/5050bL_SDK//DriveSDK/ && .install/-driveworks/dwx_startup” -d=/home/shane/NVIDIA/Drive/5050bL_SDK///_installer/tmp -l=/home/shane/NVIDIA/Drive/5050bL_SDK///_installer/logs/driveworks_target.log
I Unplug the A-A table and tested again, the install process and the log file is exactly same.
I curious about that…
Dear zew_wang,
Could you please upload the driveworks_target.log file?
And could you please help to check below Host System Prerequisites? Thanks.
You may also need to install (using apt-get install) the following packages:
libx11-dev
libxrandr-dev
libxcursor-dev
libxxf86vm-dev
libxinerama-dev
libxi-dev
libglu1-mesa-dev
libglew-dev
Hi,SteveNV, Thanks for your reply. I will check if I have installed the packages you mentioned.
Additionally, I think it’s necessary to describe the situation in detail
I choosed to flash both the Tegras and didn’t select to install CUDA and Driveworks on px2, since I think I can install both of them after flashing Tegra.
When the flashing is complete, I found the CUDA-9.0 has been installed on PX2, but I didn’t choose to install it. However, Driveworks has not been installed on px2, so I’m going to install Driveworks on PX2 with DriveInstall, but it failed.
this is the output from terminal:
0
/home/shane/NVIDIA/Drive/5050bL_SDK///_installer/run_command -c="cd /home/shane/NVIDIA/Drive/5050bL_SDK//DriveSDK/ && .install/*-driveworks*/dwx_startup" -d=/home/shane/NVIDIA/Drive/5050bL_SDK///_installer/tmp -l=/home/shane/NVIDIA/Drive/5050bL_SDK///_installer/logs/driveworks_target.log
Installing DriveWorks debs ...
There’s very little content in the driveworks_target.log file, there is only two lines:
Done.
I want to know if there is any issue with my procedures, if I should select install both CUDA and Driveworks when flashing Tegra, or install both CUDA and Driveworks after flashing…
Dear zew_wang,
Could you please try to install by selecting all of the options including CUDA and DW?
Regarding “I choosed to flash both the Tegras and didn’t select to install CUDA and Driveworks on px2, since I think I can install both of them after flashing Tegra.”, is there any reason for this?
And could you please help to check below files in download folder on your host PC?
  1. driveworks-cross-v0.6.67-drive-t186ref-ubuntu1604-5.0.5.0a.deb
  2. driveworks-v0.6.67-linux-amd64-ubuntu1604.deb
  3. drive-t186ref-5.0.5.0-aarch64-driveworks-v0.6.67.run
hi, SteveNV
I’m pretty sure that the three packages you mentioned are on my PC.
I flash tegra without install cuda and driveworks because I think I can install it after flashing.
but have a question about why cuda-9.0 have been installed on px2, and driveworks haven’t, I curious about that.
I will try to install by selecting all the cuda, driveworks and flash tegra.
Thanks SteveNV, thank you so much.
I have installed driveworks correctly on my dpx2 as you said, reflashing and selecting all.
Thanks…
Thanks…
