We are working on DriveWorks on DrivePX2 and we would also like to run it on a laptop with a GTX1050.
Ideally, we would like to execute the same application under Windows and Linux.
Thanks,
Best Regards,
Xavier
Hello Steve,
I was thinking about DriveWorks on Windows on my laptop (with a GTX1050).
I saw few slides talking about a pre-release available for Windows 10 x64.
I will try to re-install the drivers but is there a recommended version for DriveWorks/Ubuntu 14.04?
Thanks,
Xavier
Hello Steve,
I tried to install again the drivers even with the official release from your website (NVIDIA-Linux-x86_64-378.13.run). I’m still facing the same issue.
My question is: is there any chance to find an appropriate driver for Ubuntu 14.04.3x64 (the one I must use according to DriveWorks documentation for DrivePX2) supporting my GTX1050?
If yes, which one and how to install it?
Otherwise, what would be the solution?
Thanks,
Xavier
Hello XavierR,
I’m also using GTX1050Ti.
Could you please try to install graphic driver with below my installation way?
- Display Driver installation
sudo apt-get install default-jre default-jre-headless fonts-dejavu-extra java-common lib32gcc1 libatk-wrapper-java libatk-wrapper-java-jni libbonobo2-0 libbonobo2-common libc6-i386 libgconf2-4 libgif4 libgnome2-0 libgnome2-bin libgnome2-common libgnomevfs2-0 libgnomevfs2-common libidl-common libidl0 liborbit-2-0 liborbit2 libvdpau1 libxmu-dev libxmu-headers ocl-icd-libopencl1 openjdk-7-jre openjdk-7-jre-headless screen-resolution-extra tzdata-java ca-certificates-java
cd /etc/modprobe.d/
sudo su
sudo cat > blacklist-nouveau.conf
blacklist nouveau
options nouveau modeset=0
sudo update-initramfs -u
sudo reboot
sudo /etc/init.d/lightdm stop
CTRL+ALT+F1
* Check the latest driver version on www.nvidia.com → driver
cd Downloads
sudo wget http://us.download.nvidia.com/XFree86/Linux-x86_64/375.39/NVIDIA-Linux-x86_64-375.39.run
sudo chmod +x NVIDIA-Linux-x86_64-375.26.run
sudo ./NVIDIA-Linux-x86_64-375.26.run
Hello Steve,
Thanks for the explanation.
I completely reinstalled Ubuntu 14.04.3x64 on my computer prior to follow your instructions.
Everything went well except a message at the beginning of driver installation:
“The distribution-provided pre-install script failed! Are you sure you want to continue?”
Then, I reached the end of the installation without issue.
Unfortunately, I’m still facing the same issue: I’m not able to login (graphically) anymore…
Do you have any idea?
Any log file or diagnostic that might be helpful for debugging this issue?
Thanks,
Xavier
Maybe one more thing: our laptop is a DELL XPS 15 with NVidia & Intel graphics.
Is the issue somehow related to Optimus?
Hello XavierR,
Could you please try to install GPU driver with dGPU only mode?
I’m not sure how to enable dGPU only mode on DELL XPS15, maybe I think it’s better to ask DELL team it. Thanks.
Unfortunately, this seems to be impossible.
Is this issue linked to the error message that we got during drivers installation?
Does that means that you do not support Optimus or similar under Ubuntu 14?
Thanks,
Xavier
