DRM Issue JAO 64GB
Hi there,
Having an issue with HDMI output. Sometimes it will output, sometimes not. Even when outputting, the drm still shows disabled for card1-HDMI. If it does output, it will only last a few minutes from boot - almost as if something is reloaded and then display is rerouted.
My current hardware: HDMI_DP2 routed to HDMI. PINMUX, I2C and HPD all wired according to a previous forum with @WayneWWW.
I would like to clarify this again.
Please do not mix up xrandr situation with your DRM card1 result.
When you have issue with HDMI output, what is the result of your xrandr? Does it show you connected or not connected?
dev@tegra-ubuntu:~$ export DISPLAY=:0
dev@tegra-ubuntu:~$ xrandr
Screen 0: minimum 8 x 8, current 3840 x 2160, maximum 32767 x 32767
HDMI-0 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 1872mm x 1053mm
3840x2160 30.00*+ 59.94 50.00 29.97 25.00 23.98
4096x2160 59.94 50.00 29.97 25.00 24.00 23.98
1920x1080 60.00 59.94 50.00 29.97 25.00 23.98
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1366x768 59.79
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94
The monitor seems not same as the one you tested in this post.
Please align the monitor first.
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 60.00*+ 100.00 59.94 50.00
1600x900 60.00
1280x720 75.00 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
Also, after rebooting a few times, HDMI at the HDMI_DP2 ports are lost. Now no HDMI output.
So what do you see in this situation? No Ubuntu desktop there?
Yes, now it no longer outputs at all - no ubuntu desktop screen showing.
What is the result of xrandr after you unplug the HDMI cable?
HDMI-0 disconnected primary (normal left inverted right x axis y axis)
Do you have any conclusion what would make your Ubuntu desktop come back?
For example, if you hotplug for like 10 times now, will it show up any once?
Doesnt show up at all even after unplugging/plugging in HDMI a few times. Will reflash to see if it works again. Typically works after reflash for first few boots.
Did you ever run something like sudo apt-get upgrade or install nvidia-jetpack before this issue ever happened?
Nope, I havent run anything on these - theyre fresh flashes
When the monitors are working fine, will it always work or even intermittently work only?
I mean for example, reboot 10 times or hotplug 10 times and it will always work.
No, not always working. So here is an example:
  • i reflash with the same image
  • I boot up with HDMI connected
  • I see HDMI output, but this only lasts 1-2 minutes
So even if you have activities (not entering any power save situation), it still goes down in 1-2 mins?
Yes, I was actually searching through settings when the hdmi cut off and stopped - then never came back even after a few reboots/hotplugging
I don’t feel this kind of behavior has anything to do with software.
Pinmux/device tree update always require to reboot to take effect. It won’t just got changed when no reboot happened on your board.
Please also check command “lsmod” and dmesg before and after your problem happened by using UART serial console. Especially check if dmesg print anything new.
This is right after the boot, while the hdmi is outputting and I can see ubuntu desktop
RightAfterBoot.txt (156.3 KB)
Then after the HDMI has stopped (no new dmesg):
afterHDMIFail.txt (6.9 KB)
Please review your hardware. Not a problem from software I think.
