Hi,nvidia teams;
There is an occasional bug on our board. it will drop frames when using camera sometimes , but if reboot, the bug no longer appears. when frame drop is happenning, we try only reset the deserializer “max96712” or only reset the camera module, frame drop still exist. but when we only reboot orin (keep “max96712” and camera module power on), the frame drop disappeared. the log is in theattachment, please help to analyze.
dmesg.log (108.7 KB)
trace.log (10.2 MB)
trace_eof.log (314.9 KB)
hello 261136636,
there’re several questions and suggestions…
may I know which Jetpack release version you’re using?
could you please also share the system clock configuration, please try using
nvpmodel
to switch the config as MaxN (performance mode) for testing. -
there’re i2c communication errors, please dig into this
i2c write failed
, and try to resolve this sensor level issue.
[ 182.534678] max9295a 2-0040: max9295_write_reg:i2c write failed, 0x2be = 10
[ 182.542776] max9295a 2-0040: max9295_write_reg:i2c write failed, 0x318 = 5e
[ 182.550862] max9295a 2-0040: max9295_write_reg:i2c write failed, 0x2d3 = 0
[ 183.590854] max9295a 2-0040: max9295_write_reg:i2c write failed, 0x2d3 = 10
how many cameras and what’s the resolution you’re launching for testing? please also share your pipeline for reference.
BTW, there’s
argus_camera
sample application, you could enable--kpi
options to enable performance analysis functions.
Hi,JerryChang:
Thanks for your reply;
1.The Jetpack we used is “https://developer.nvidia.com/embedded/jetson-linux-r351”;
2. I will try using nvpmodel to switch the config as MaxN (performance mode) for testing;
3.The i2c communication errors can be ignored, the reason is some ports do not connect camera module.
4.We use 1 or 2 camera module. the resolution is “1920 x 1080” and “3840 x 2160”, the command we used is:
“gst-launch-1.0 v4l2src device=/dev/video0 ! ‘video/x–raw, format=UYVY, width=1920, height=1080, framerate=30/1’ ! xvimagesink -ev”
I upload the dts file to describe the pipeline;
5. How to download “argus_camera”? I do not find it in default file system;
tegra234-camera-imx390-a01.dtsi (47.7 KB)
please ignore my previous item-5 since argus_camera
sample application doesn’t support with YUV sensor types.
Hi,JerryChang:
When dropping frame, the log is like this , so do you have some suggesiton?
kworker/2:0-4382 [002] … 501.065549: rtcpu_vinotify_event: tstamp:16273387072 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:520739504128 data:0x00000000020210f0
kworker/2:0-4382 [002] .... 501.065550: rtcpu_vinotify_event: tstamp:16273387220 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:520739501280 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.065550: rtcpu_vinotify_event: tstamp:16273387351 cch:0 vi:1 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:520739501280 data:0x0000000800000000*
kworker/2:0-4382 [002] .... 501.065550: rtcpu_vinotify_event: tstamp:16273387501 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:520739510368 data:0x00000000000210f0*
kworker/2:0-4382 [002] .... 501.065550: rtcpu_vinotify_event: tstamp:16273387631 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:520740359168 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.065551: rtcpu_vinotify_event: tstamp:16273387780 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520740857920 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.121540: rtcpu_vinotify_event: tstamp:16274151648 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:520772834848 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.121540: rtcpu_vinotify_error: tstamp:16274194222 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520774191136 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.121540: rtcpu_vinotify_event: tstamp:16274468483 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:520773692416 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.121541: rtcpu_vinotify_event: tstamp:16274468613 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520774191136 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.121542: rtcpu_vinotify_error: tstamp:16275235895 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520807524736 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.121542: rtcpu_vinotify_event: tstamp:16275482626 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:520806168032 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.121542: rtcpu_vinotify_event: tstamp:16275482758 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:520807025952 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.121542: rtcpu_vinotify_event: tstamp:16275482911 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520807524736 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.177546: rtcpu_vinotify_error: tstamp:16276277557 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520840857920 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.177546: rtcpu_vinotify_event: tstamp:16276496771 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:520839501632 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.177546: rtcpu_vinotify_event: tstamp:16276496926 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:520840359200 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.177547: rtcpu_vinotify_event: tstamp:16276497060 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520840857920 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.177547: rtcpu_vinotify_error: tstamp:16277319230 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520874191488 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.177547: rtcpu_vinotify_event: tstamp:16277510899 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:520872834848 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.177547: rtcpu_vinotify_event: tstamp:16277511031 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:520873692736 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.177548: rtcpu_vinotify_event: tstamp:16277511181 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520874191488 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.233653: rtcpu_vinotify_error: tstamp:16278360892 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520907524736 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.233655: rtcpu_vinotify_event: tstamp:16278525040 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:520906168096 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.233655: rtcpu_vinotify_event: tstamp:16278525192 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:520907025920 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.233656: rtcpu_vinotify_event: tstamp:16278525323 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520907524736 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.233656: rtcpu_vinotify_event: tstamp:16279386792 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:520939501632 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.233656: rtcpu_vinotify_event: tstamp:16279386924 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:520940359520 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.289547: rtcpu_vinotify_error: tstamp:16279402556 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520940857984 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.289550: rtcpu_vinotify_event: tstamp:16279708213 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520940857984 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.289550: rtcpu_vinotify_error: tstamp:16280444229 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520974191488 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.289550: rtcpu_vinotify_event: tstamp:16280722352 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:520972834880 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.289551: rtcpu_vinotify_event: tstamp:16280722501 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:520973692736 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.289551: rtcpu_vinotify_event: tstamp:16280722631 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:520974191488 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.345651: rtcpu_vinotify_error: tstamp:16281485892 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521007524704 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.345653: rtcpu_vinotify_event: tstamp:16281736493 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521006168416 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.345653: rtcpu_vinotify_event: tstamp:16281736624 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521007026304 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.345653: rtcpu_vinotify_event: tstamp:16281736777 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521007524704 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.345653: rtcpu_vinotify_error: tstamp:16282527566 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521040858304 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.345654: rtcpu_vinotify_event: tstamp:16282750641 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521039501600 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.345654: rtcpu_vinotify_event: tstamp:16282750792 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521040359488 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.345654: rtcpu_vinotify_event: tstamp:16282750923 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521040858304 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.401544: rtcpu_vinotify_error: tstamp:16283569227 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521074191488 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.401545: rtcpu_vinotify_event: tstamp:16283764776 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521072835200 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.401545: rtcpu_vinotify_event: tstamp:16283764908 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521073692736 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.401546: rtcpu_vinotify_event: tstamp:16283765062 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521074191488 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.401546: rtcpu_vinotify_error: tstamp:16284610886 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521107525056 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.401546: rtcpu_vinotify_event: tstamp:16284611324 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521106168416 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.401546: rtcpu_vinotify_event: tstamp:16284611477 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521107026304 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.401546: rtcpu_vinotify_event: tstamp:16284611611 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521107525056 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.457550: rtcpu_vinotify_event: tstamp:16285624055 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521139501984 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.457552: rtcpu_vinotify_error: tstamp:16285652567 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521140858272 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.457552: rtcpu_vinotify_event: tstamp:16285962032 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521140359552 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.457552: rtcpu_vinotify_event: tstamp:16285962184 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521140858272 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.513659: rtcpu_vinotify_error: tstamp:16286694242 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521174191872 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.513662: rtcpu_vinotify_event: tstamp:16286976185 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521172835200 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.513662: rtcpu_vinotify_event: tstamp:16286976337 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521173693088 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.513662: rtcpu_vinotify_event: tstamp:16286976468 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521174191872 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.513662: rtcpu_vinotify_error: tstamp:16287735905 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521207525056 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.513662: rtcpu_vinotify_event: tstamp:16287990324 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521206168416 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.513663: rtcpu_vinotify_event: tstamp:16287990455 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521207026272 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.513663: rtcpu_vinotify_event: tstamp:16287990608 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521207525056 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.569653: rtcpu_vinotify_error: tstamp:16288777567 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521240858336 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.569655: rtcpu_vinotify_event: tstamp:16289004467 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521239501984 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.569656: rtcpu_vinotify_event: tstamp:16289004621 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521240359872 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.569656: rtcpu_vinotify_event: tstamp:16289004754 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521240858336 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.569656: rtcpu_vinotify_error: tstamp:16289819239 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521274191840 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.625546: rtcpu_vinotify_event: tstamp:16290018633 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521272835264 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.625548: rtcpu_vinotify_event: tstamp:16290018764 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521273693056 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.625549: rtcpu_vinotify_event: tstamp:16290018916 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521274191840 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.625549: rtcpu_vinotify_event: tstamp:16290818333 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521306168768 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.625550: rtcpu_vinotify_error: tstamp:16290860905 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521307525120 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.625550: rtcpu_vinotify_event: tstamp:16291134063 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521307026656 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.625551: rtcpu_vinotify_event: tstamp:16291134195 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521307525120 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.681652: rtcpu_vinotify_error: tstamp:16291902578 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521340858624 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.681654: rtcpu_vinotify_event: tstamp:16292148207 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521339501984 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.681654: rtcpu_vinotify_event: tstamp:16292148338 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521340359872 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.681654: rtcpu_vinotify_event: tstamp:16292148489 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521340858624 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.681654: rtcpu_vinotify_error: tstamp:16292944240 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521374191840 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.681655: rtcpu_vinotify_event: tstamp:16293162352 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521372835552 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.681655: rtcpu_vinotify_event: tstamp:16293162501 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521373693120 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.681655: rtcpu_vinotify_event: tstamp:16293162631 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521374191840 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.737654: rtcpu_vinotify_error: tstamp:16293985912 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521407525408 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.737656: rtcpu_vinotify_event: tstamp:16294176490 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521406168768 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.737656: rtcpu_vinotify_event: tstamp:16294176620 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521407026624 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.737656: rtcpu_vinotify_event: tstamp:16294176773 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521407525408 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.737657: rtcpu_vinotify_error: tstamp:16295027575 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521440858624 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.793653: rtcpu_vinotify_event: tstamp:16295190634 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521439502336 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.793656: rtcpu_vinotify_event: tstamp:16295190783 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521440359904 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.793656: rtcpu_vinotify_event: tstamp:16295190913 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521440858624 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.793656: rtcpu_vinotify_event: tstamp:16296053479 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521472835552 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.793657: rtcpu_vinotify_event: tstamp:16296053611 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521473693440 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.793658: rtcpu_vinotify_error: tstamp:16296069254 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521474192192 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.793658: rtcpu_vinotify_event: tstamp:16296373802 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521474192192 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.849653: rtcpu_vinotify_error: tstamp:16297110914 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521507525440 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.849656: rtcpu_vinotify_event: tstamp:16297387941 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521506168800 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.849656: rtcpu_vinotify_event: tstamp:16297388093 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521507026624 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.849656: rtcpu_vinotify_event: tstamp:16297388228 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521507525440 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.849656: rtcpu_vinotify_error: tstamp:16298152587 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521540859008 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.849657: rtcpu_vinotify_event: tstamp:16298402085 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521539502336 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.849657: rtcpu_vinotify_event: tstamp:16298402216 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521540360224 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.849657: rtcpu_vinotify_event: tstamp:16298402369 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521540859008 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.905653: rtcpu_vinotify_error: tstamp:16299194249 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521574192192 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.905655: rtcpu_vinotify_event: tstamp:16299416223 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521572835584 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.905655: rtcpu_vinotify_event: tstamp:16299416372 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521573693440 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.905656: rtcpu_vinotify_event: tstamp:16299416503 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521574192192 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.905656: rtcpu_vinotify_error: tstamp:16300235913 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521607525376 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.961543: rtcpu_vinotify_event: tstamp:16300430366 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521606169088 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.961545: rtcpu_vinotify_event: tstamp:16300430497 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521607027008 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.961545: rtcpu_vinotify_event: tstamp:16300430650 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521607525376 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.961547: rtcpu_vinotify_error: tstamp:16301277570 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521640858976 data:0x00000000000003c9*
kworker/2:0-4382 [002] .... 501.961547: rtcpu_vinotify_event: tstamp:16301278003 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:521639502304 data:0x0000000000000025*
kworker/2:0-4382 [002] .... 501.961547: rtcpu_vinotify_event: tstamp:16301278152 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:521640360192 data:0x0000000000000015*
kworker/2:0-4382 [002] .... 501.961547: rtcpu_vinotify_event: tstamp:16301278282 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:521640858976 data:0x00000000000003c9*
hello 261136636,
could you please re-format those tracing logs, you may encapsulation them as single code block, or, you may attach them as single text file.
BTW,
please also examine the sensor support formats… $ v4l2-ctl -d /dev/video0 --list-formats-ext
please update those resolution and pixel format property and issue the v4l ioctl to access the stream, it’ll also report the fps below the pipeline.
for example,
$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100
