I am occasionally getting dropped/corrupted frames during recordings using my Gstreamer pipeline. It occurs intermittently and seems random. At first I thought it might be occurring during periods of high motion, but in the attached image the camera is just pointing at a picture on a wall, i.e. the image is static. The gray frames persist for ~5-10 frames and then recover.
may I know which Jetpack release version you’re now working with?
had you configure the system to performance mode, i.e. MaxN? had you also tried h264?
@JerryChang I can’t recall if I ever saw the gray screen issue with h264, it has been a bit since I last tried that encoder. However, today I did prepare a new pipeline using a h264 with CBR, and also changed the profile to main and the preset-level to 2. This seems to do well in an office environment, but I will test it tomorrow in the field.
Either way, I would still like to understand why I am seeing the issue with the h265 encoder. Is it a likely issue with the encoder itself, or just my settings (e.g. VBR vs CBR, profile, preset-level, etc)?
you may also narrow down the issue to store the content locally for confirmation.
here’s example to preview stream and doing h265 video recording. $ gst-launch-1.0 nvarguscamerasrc num-buffers=300 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1' ! tee name=streams streams. ! queue ! nvv4l2h265enc bitrate=8000000 ! h265parse ! qtmux ! filesink location=h265.mp4 streams. ! queue ! nvvidconv ! xvimagesink -e
