• Hardware Platform (Jetson / GPU) - Jetson AGX
• DeepStream Version - v5.1
• TensorRT Version
• Issue Type( questions, new requirements, bugs) questions
I tried to modify the deepstream-app sample code in DS SDK v5.1 to add in a filesink to save the input video immediately after the input filesrc, as below. The pipeline is working when file-loop=0. Once the file-loop is enabled, the pipeline not able to enter PLAYING state and keep on stay at READY state
gst filesrc → gst tee -| → gst decodebin ->… the rests of the bin/elements after decodebin remains unchanged
-| → gst queue → gst qt-demux → gst h264 parser → gst qt-mux → gst filesink
(the gst decodebin and gst queue are connected after the gst tee)
Here is the pipeline graph
0.00.03.748588791-ds-app-playing.pdf (52.6 KB)
I tried to add message print at the restart_stream_buf_prob() function to check the event type received. Below is the snippet of the log
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:186>: Pipeline ready
Opening in BLOCKING MODE
CE: restart_stream_buf_prob ENTER
CE: restart_stream_buf_prob exit with OK with event type 10254
CE: restart_stream_buf_prob exit with OK with event type 12814
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
CE: restart_stream_buf_prob exit with error with event type 5127
CE: restart_stream_buf_prob exit with error with event type 17934
CE: restart_stream_buf_prob exit with OK with event type 20510
CE: restart_stream_buf_prob exit with OK with event type 0
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
**PERF: 0.00 (0.00)
Is it due to some missing event causing the pipeline not able to enter PLAYING state?
Any pointer what could have missing or misconfigured in the pipeline that is causing this issue?
