xutao3
July 5, 2024, 10:58am
1
I am testing the Deepstream_Tao_apps (GitHub - NVIDIA-AI-IOT/deepstream_tao_apps: Sample apps to demonstrate how to deploy models trained with TAO on DeepStream ), and as the guide, I ran the command:
./apps/tao_detection/ds-tao-detection -c configs/dssd_tao/pgie_dssd_tao_config.txt -i file:///$DS_SRC_PATH/samples/streams/sample_720p.mp4
and reported following error:
(tao) nvidia@ubuntu:~/WS/TAO/deepstream_tao_apps$ ./apps/tao_detection/ds-tao-detection -c configs/nvinfer/dssd_tao/pgie_dssd_tao_config.txt -i file:///$DS_SRC_PATH/samples/streams/sample_720p.mp4
Request sink_0 pad from streammux
terminate called after throwing an instance of ‘YAML::BadFile’
what(): bad file: -c
Aborted (core dumped)
And it is same using the
/apps/tao_detection/ds-tao-detection -c configs/nvinfer/dssd_tao/pgie_dssd_tao_config.yml -i file:///$DS_SRC_PATH/samples/streams/sample_720p.mp4
However, it runs successfully the following command:
./apps/tao_detection/ds-tao-detection configs/app/det_app_frcnn.yml (enable the config-file-path: …/nvinfer/dssd_tao/pgie_dssd_tao_config.yml)
What’s the problem? Bug in code?
Will move to Deepstream forum for tracking.
It’s a bug, will be fixed next version. It’s open source, you can fixed it or try this patch.
diff --git a/apps/tao_detection/deepstream_det_app.c b/apps/tao_detection/deepstream_det_app.c
index ce4e864..e8a13ee 100644
--- a/apps/tao_detection/deepstream_det_app.c
+++ b/apps/tao_detection/deepstream_det_app.c
@@ -484,6 +484,28 @@ det_bus_call (GstBus * bus, GstMessage * msg, gpointer data) {
return TRUE;
+static bool
+is_enc_hw_support() {
+ int current_device = -1;
+ cudaGetDevice(¤t_device);
+ struct cudaDeviceProp prop;
+ cudaGetDeviceProperties(&prop, current_device);
+ bool enc_hw_support = TRUE;
+ if (prop.integrated) {
+ char device_name[50];
+ FILE* ptr = fopen("/proc/device-tree/model", "r");
+ if (ptr) {
+ while (fgets(device_name, 50, ptr) != NULL) {
+ if (strstr(device_name,"Orin") && (strstr(device_name,"Nano")))
+ enc_hw_support = FALSE;
+ fclose(ptr);
+ return enc_hw_support;
/* Check for parsing error. */
#define RETURN_ON_PARSER_ERROR(parse_expr) \
if (NVDS_YAML_PARSER_SUCCESS != parse_expr) { \
@@ -688,7 +710,7 @@ main (int argc, char *argv[]) {
/* Finally render the osd output */
- if(isYAML) {
+ if (isYAML) {
GstElement *eglsink = gst_element_factory_make ("nveglglessink", "test-egl-sink");
GstElement *filesink = gst_element_factory_make ("filesink", "test-file-sink");
GstElement *fakesink = gst_element_factory_make("fakesink", "test-fake-sink");
@@ -709,14 +731,18 @@ main (int argc, char *argv[]) {
const char* use_display = std::getenv("USE_DISPLAY");
- if(use_display != NULL && std::stoi(use_display) == 1) {
+ if (use_display != NULL && std::stoi(use_display) == 1) {
useDisplay = true;
- if(useDisplay == FALSE) {
+ if (useDisplay == FALSE) {
if(isImage == FALSE){
parser1 = gst_element_factory_make ("h264parse", "h264-parser1");
- parse_filesink_yaml(&enc_type, argv[1]);
+ if (isYAML) {
+ parse_filesink_yaml(&enc_type, argv[1]);
+ } else {
+ enc_type = is_enc_hw_support();
if(enc_type == 0){
enc = gst_element_factory_make ("nvv4l2h264enc", "h264-enc");
} else {
@@ -755,7 +781,7 @@ main (int argc, char *argv[]) {
sink = gst_element_factory_make("nv3dsink", "nv3d-sink");
else
#ifdef __aarch64__
- sink = gst_element_factory_make("nv3dsink", "nv3d-sink");
+ sink = gst_element_factory_make("nv3dsink", "nv3d-sink");
#else
sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
#endif
system
Closed
July 22, 2024, 3:33am
5
