[DS4] Gstreamer custom plugin with secondary classifier
I have a custom gstreamer plugin based on provided ds-example plugin. Its works well with primary detectors output.
Now I have added a secondary classifier to the pipeline , but it seems classier meta is not accessible to the custom plugin,
As my use case is to use both primary detector and secondary classifer output to be available at the custom plugin can you share some pointer to it ?
I have analyed the gstreamer graph visualisation and it seems at the secondary classifier level a “tee” is there which is avoiding the classifier output to be fed to custom plugin.
Regards
Pallab Sarkar
Able to solve this !!!
