Hi
I am facing a issue when my input sorce is RTSP and I am enabling the Tacker it giving error,
But if input sorce is a mp4 file and enable the tracker its working fine
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://<>:554
num-sources=1
gpu-id=0
cudadec-memtype=0
[tracker]
enable=1
tracker-width=480
tracker-height=272
enable-batch-proces = 1
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
gpu-id=0
Error LOg
** INFO: <bus_callback:163>: Pipeline ready
** ERROR: <cb_newpad3:396>: Failed to link depay loader to rtsp src
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:149>: Pipeline running
Creating LL OSD context new
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
gstnvtracker: NvBufSurfTransform failed with error -2 while converting buffergstnvtracker: Failed to convert input batch.
ERROR from tracking_tracker: Failed to submit input to tracker
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvtracker2/gstnvtracker.cpp(511): gst_nv_tracker_submit_input_buffer (): /GstPipeline:pipeline/GstBin:tracking_bin/GstNvTracker:tracking_tracker
0:00:04.584594783 8994 0x5067ed0 WARN nvinfer gstnvinfer.cpp:1830:gst_nvinfer_output_loop:<primary_gie_classifier> error: Internal data stream error.
0:00:04.584667754 8994 0x5067ed0 WARN nvinfer gstnvinfer.cpp:1830:gst_nvinfer_output_loop:<primary_gie_classifier> error: streaming stopped, reason error (-5)
ERROR from primary_gie_classifier: Internal data stream error.
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(1830): gst_nvinfer_output_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier:
Quitting
App run failed
Also If I disbale the tracker then RTSP works fine with no issue
Please suggest some pointers to solve this issue.
Regards
Pallab Sarkar
