Ds6.0: how can I reset nvdsanalytics state?
I am doing video analytics on prerecorded video files. At the end of each video clip, it appears the nvtracker is resetting the tracking IDs, however the internal states of nvdsanalytics is not reset, (in the OSD, I can see the line crossing counter starts with previous clip’s value), in result on the second video clip the line crossing would fail to detect line crossing.
the structure of the pipeline:
uridecodebin->nvstreammux->nvinfer->nvtracker->nvdsanalytics->nvstreamdemux->nvdsosd->nvoverlaysink
Is there a way to reset the nvdsanalytics state in ds6.0? Thanks.
• DeepStream Version
• TensorRT Version
Deepstream version 6.0.
L4T: 32.7.5
Hardware: TX2.
could you share the screenshot of the first clip end and the second clip start? if objects change, new objects will get a new tracker id.
could you share some screenshot or video to elaborate this issue? Thanks!
  1. How long is the mp4? will these cars in the screenshot disappear from the video? Noticing all trackerid did not changed in the second run. yes, line crossing counter is accumulative.
  2. nvdsanalytics plugin is opensource in DS6.3. you can reload the cfg to recreate low-level instance. By this way, all counter will start from 0. please refer to this topic for how to reload cfg.
Thanks for your reply, @fanzh.
  1. The clip is short, only about 10 seconds, but the red car of interest did get out of view.
  2. Since I am using TX2, I believe I am stuck at DS6.0, so that DS6.3 solution won’t apply to my situation. Correct me if I am wrong on this.
you can copy the code /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvdsanalytics/ from DS6.3 to DS6.0. then build it according to the readme. especially you need to replace /opt/nvidia/deepstream/deepstream/lib/gst-plugins/libnvdsgst_dsanalytics.so with the new so. please backup the original so first.
