GPU • DeepStream Version
6.0 • JetPack Version (valid for Jetson only) • TensorRT Version
8.0.1 • NVIDIA GPU Driver Version (valid for GPU only)
471.41 • Issue Type( questions, new requirements, bugs)
Question • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Gst-nvtracker
With the new DS 6.0 release we’re able to use DeepSORT with custom a custom Re-Id implementation. While the tracker uses the Re-Id vectors internally to estimate similarities between detections, we require the Re-Id vectors futher down our pipeline. Is it possible to extract the Re-Id vectors as a part of the NvDsBatchMeta for further processing (or in any other way)?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
