OS: Ubuntu 20.04
GST: 1.16.3
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.1
• TensorRT Version 8.2.5.1
• NVIDIA GPU Driver Version (valid for GPU only) 515.48.07
• Issue Type( questions, new requirements, bugs) Questions/Bugs
The pipeline SRC=./vid.mp4 && gst-launch-1.0 -v filesrc location="$SRC" ! qtdemux ! h264parse ! decodebin ! videoconvert ! autovideosink
works perfectly if DS6.1 is not installed, but gives the following error once it is:
/GstPipeline:pipeline0/GstDecodeBin:decodebin0.GstDecodePad:src_0.GstProxyPad:proxypad2: caps = video/x-raw(memory:NVMM), format=(string)NV12, width=(int)480, height=(int)270, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1
WARNING: from element /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0: not negotiated
ERROR: from element /GstPipeline:pipeline0/GstQTDemux:qtdemux0: Internal data stream error.
Additional debug info:
../subprojects/gstreamer/libs/gst/base/gstbasetransform.c(1431): gst_base_transform_reconfigure_unlocked (): /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter0:
not negotiated
../subprojects/gst-plugins-good/gst/isomp4/qtdemux.c(6749): gst_qtdemux_loop (): /GstPipeline:pipeline0/GstQTDemux:qtdemux0:
streaming stopped, reason not-negotiated (-4)
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
The pipeline also works fine in a development environment (python gst-env.py
) where DS plugins aren’t available.
