HI WayneWWW:
The log is as follow.
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38 (meyan@ubuntu) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #86 SMP PREEMPT Thu Jan 11 19:17:41 CST 2018 sum-v0.1
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] Reserved memory: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Reserved memory: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 16 MiB at 0x00000000fdc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc0ffe40000 s31256 r8192 d30184 u69632
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1027072
[ 0.000000] Kernel command line: root=/dev/mmcblk0p18 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 androidboot.modem=none androidboot.serialno=03216171242700408200 androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootloader=00.00.2014.50-t210-fadd1be5 androidboot.verifiedbootstate=orange root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3372860K/4173824K available (10965K kernel code, 1822K rwdata, 6444K rodata, 1200K init, 688K bss, 96452K reserved, 704512K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
[ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
[ 0.000000] 0xffffffbdc2000000 - 0xffffffbdc6000000 ( 64 MB actual)
[ 0.000000] fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
[ 0.000000] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc100000000 ( 4096 MB)
[ 0.000000] .init : 0xffffffc001181000 - 0xffffffc0012ad000 ( 1200 KB)
[ 0.000000] .text : 0xffffffc000080000 - 0xffffffc001180d64 ( 17412 KB)
[ 0.000000] .data : 0xffffffc0012c7000 - 0xffffffc00148ea30 ( 1823 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] enable_t210_agic_clks:106 ape clocked & reset cleared
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] kmemleak: Kernel memory leak detector disabled
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001223] Console: colour dummy device 80x25
[ 0.002165] console [tty0] enabled
[ 0.002195] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.002234] pid_max: default: 32768 minimum: 301
[ 0.002316] Security Framework initialized
[ 0.002337] SELinux: Initializing.
[ 0.002442] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.002466] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003145] Initializing cgroup subsys freezer
[ 0.003175] Initializing cgroup subsys debug
[ 0.003446] CPU0 ipc=1024
[ 0.003482] CPU1 ipc=1024
[ 0.003513] CPU2 ipc=1024
[ 0.003544] CPU3 ipc=1024
[ 0.003611] ASID allocator initialised with 65536 entries
[ 0.025829] tegra-id: chipid=22117.
[ 0.025857] tegra-id: opt_subrevision=0.
[ 0.025888] Tegra Speedo/IDDQ fuse revision 4
[ 0.025908] Tegra: CPU Speedo ID 7, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.025929] Tegra: CPU Process ID 0, SoC Process ID 0, GPU Process ID 0
[ 0.025950] Tegra: CPU Speedo Value 2015, SoC Speedo Value 1885, GPU Speedo Value 2003
[ 0.025981] Tegra: CPU IDDQ Value 1584, SoC IDDQ Value 1604, GPU IDDQ Value 2060
[ 0.026024] Tegra Revision: A02 SKU: 0x17 CPU Process: 0 SoC Process: 0
[ 0.027054] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-sum.dts
[ 0.027095] DTB Build time: Jan 9 2018 11:02:32
[ 0.040770] CPU1: Booted secondary processor [411fd071]
[ 0.052743] CPU2: Booted secondary processor [411fd071]
[ 0.064738] CPU3: Booted secondary processor [411fd071]
[ 0.064810] Brought up 4 CPUs
[ 0.064881] SMP: Total of 4 processors activated.
[ 0.064906] CPU: All CPU(s) started at EL2
[ 0.064948] alternatives: patching kernel code
[ 0.067372] devtmpfs: initialized
[ 0.121148] Initilizing CustomIPI irq domain
[ 0.121490] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.133498] pinctrl core: initialized pinctrl subsystem
[ 0.133723] OS set in device tree is L4T.
[ 0.134108] regulator-dummy: no parameters
[ 0.134329] Initializing plugin-manager
[ 0.134404] Plugin module not found
[ 0.134591] node /plugin-manager/fragement@0 match with board >=2180-1000-300
[ 0.135340] node /plugin-manager/fragement@4 match with odm-data l4t
[ 0.135451] Removing Prop nvidia,pmc-wakeup from target /bcmdhd_wlan
[ 0.135934] Adding domain ape-pd to PM domain mc-clk-pd
[ 0.135978] Adding domain adsp-pd to PM domain ape-pd
[ 0.139650] NET: Registered protocol family 16
[ 0.154223] console [pstore-1] enabled
[ 0.154246] pstore: Registered ramoops as persistent store backend
[ 0.154271] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.164231] cpuidle: using governor ladder
[ 0.176220] cpuidle: using governor menu
[ 0.176568] bpmp: mail init ok
[ 0.177676] vdso: 2 pages (1 code @ ffffffc0012cd000, 1 data @ ffffffc0012cc000)
[ 0.177738] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.180052] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.180988] tegra_powergate_init: DONE
[ 0.181031] DTS File Name: arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/jetson/kernel-dts/tegra210-jetson-tx1-sum.dts
[ 0.181071] DTB Build time: Jan 9 2018 11:02:32
[ 0.182085] Error: Driver 'tegra-mc' is already registered, aborting...
[ 0.183593] platform tegra-carveouts: SMMU isn't ready yet
[ 0.184337] platform tegra-carveouts: domain=ffffffc0fa03f318 allocates as[0]=ffffffc0fa0a40a8
[ 0.184412] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.184643] platform smmu_test: domain=ffffffc0fa03f618 allocates as[0]=ffffffc0fa0a4110
[ 0.184970] platform 70016000.bpmp: domain=ffffffc0fa03f918 allocates as[0]=ffffffc0fa0a4178
[ 0.185678] bpmp: ping status is 0
[ 0.185787] bpmp 70016000.bpmp: firmware tag is 1e4b302fc0f866f97885165cf8b395ac
[ 0.186036] bpmp 70016000.bpmp: probe ok
[ 0.186665] mc: mapped MMIO address: 0xffffff800007e000 -> 0x70019000
[ 0.186765] mc: mapped MMIO address: 0xffffff80000b6000 -> 0x7001c000
[ 0.186858] mc: mapped MMIO address: 0xffffff80000dc000 -> 0x7001d000
[ 0.186946] mc-err: Set intmask: 0x23d40
[ 0.198197] GPIO line 58 (wlan-default-input-h2) hogged as input
[ 0.198245] GPIO line 65 (wlan-default-input-i1) hogged as input
[ 0.198290] GPIO line 56 (wlan-default-output-high-h0) hogged as output/high
[ 0.198331] GPIO line 64 (wlan-default-output-high-i0) hogged as output/high
[ 0.198607] gpiochip_add_data: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.201019] platform 70006000.serial: domain=ffffffc0fa0a0e18 allocates as[0]=ffffffc0fa0a41e0
[ 0.204258] platform tegradc.0: domain=ffffffc0fa13a618 allocates as[0]=ffffffc0fa0a4248
[ 0.204863] platform tegradc.0: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.205274] platform tegradc.1: domain=ffffffc0fa13a918 allocates as[0]=ffffffc0fa0a42b0
[ 0.205855] platform tegradc.1: IOVA linear map 0x00000000c6000000(2a000000)
[ 0.208574] platform 57000000.gpu: domain=ffffffc0fa151d18 allocates as[0]=ffffffc0fa0a4318
[ 0.208651] platform 57000000.gpu: domain=ffffffc0fa151d18 allocates as[1]=ffffffc0fa0a4380
[ 0.208725] platform 57000000.gpu: domain=ffffffc0fa151d18 allocates as[2]=ffffffc0fa0a43e8
[ 0.208795] platform 57000000.gpu: domain=ffffffc0fa151d18 allocates as[3]=ffffffc0fa0a4450
[ 0.209467] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.209512] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.209538] tegra-pmc: ### PMC reset source: Power on reset
[ 0.209559] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.209912] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.209948] tegra-pmc: Clear bootloader IO dpd settings
[ 0.212337] tegra-pmc 7000e400.pmc: PMC: IO pad audio voltage is 1800000
[ 0.216313] tegra-pmc 7000e400.pmc: PMC: IO pad cam voltage is 1800000
[ 0.220312] tegra-pmc 7000e400.pmc: PMC: IO pad dbg voltage is 1800000
[ 0.224311] tegra-pmc 7000e400.pmc: PMC: IO pad dmic voltage is 1800000
[ 0.224340] tegra-pmc 7000e400.pmc: PMC: IO pad pex-ctrl voltage is 1800000
[ 0.228311] tegra-pmc 7000e400.pmc: PMC: IO pad spi voltage is 1800000
[ 0.232311] tegra-pmc 7000e400.pmc: PMC: IO pad uart voltage is 1800000
[ 0.236310] tegra-pmc 7000e400.pmc: PMC: IO pad audio-hv voltage is 1800000
[ 0.236339] tegra-pmc 7000e400.pmc: PMC: IO pad spi-hv voltage is 1800000
[ 0.240310] tegra-pmc 7000e400.pmc: PMC: IO pad gpio voltage is 1800000
[ 0.244310] tegra-pmc 7000e400.pmc: PMC: IO pad sdmmc3 voltage is 1800000
[ 0.244336] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.244408] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.246414] platform adsp_audio: domain=ffffffc0fa159a18 allocates as[0]=ffffffc0fa0a44b8
[ 0.247572] platform 1003000.pcie-controller: domain=ffffffc0fa159f18 allocates as[0]=ffffffc0fa0a4520
[ 0.249881] platform sdhci-tegra.3: domain=ffffffc0fa167018 allocates as[0]=ffffffc0fa0a4588
[ 0.250488] platform sdhci-tegra.0: domain=ffffffc0fa167418 allocates as[0]=ffffffc0fa0a45f0
[ 0.255833] vdd-ac-bat: 5000 mV
[ 0.257017] vdd-cpu-fixed: 1000 mV
[ 0.260924] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.261239] irq: no irq domain found for /soctherm@0x700E2000 !
[ 0.281417] ACPI: Interpreter disabled.
[ 0.282208] SCSI subsystem initialized
[ 0.282487] usbcore: registered new interface driver usbfs
[ 0.282561] usbcore: registered new interface driver hub
[ 0.282655] usbcore: registered new device driver usb
[ 0.285398] tegra-i2c 7000c400.i2c: no acknowledge from address 0x74
[ 0.285471] pca953x 1-0074: failed reading register
[ 0.285553] pca953x: probe of 1-0074 failed with error -121
[ 0.285975] tegra-i2c 7000c400.i2c: no acknowledge from address 0x77
[ 0.286043] pca953x 1-0077: failed reading register
[ 0.286109] pca953x: probe of 1-0077 failed with error -121
[ 0.288691] max77620 4-003c: PMIC Version OTP:0x3C and ES:0x8
[ 0.290418] GPIO line 506 (spmic-default-output-high) hogged as output/high
[ 0.290539] gpiochip_add_data: registered GPIOs 504 to 511 on device: max77620-gpio
[ 0.296389] vdd-core: 600 <--> 1400 mV at 1125 mV
[ 0.300338] vddio-ddr: at 1125 mV
[ 0.301140] vdd-pre-reg: 1350 mV
[ 0.304216] vdd-1v8: 1800 mV
[ 0.308217] avdd-sys: 1200 mV
[ 0.312216] vdd-pex: 1050 mV
[ 0.312816] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[ 0.313632] vdd-cam-hv: 2800 mV
[ 0.316215] vdd-rtc: 850 mV
[ 0.317028] avdd-ts-hv: 3300 mV
[ 0.317846] vdd-ts: 1800 mV
[ 0.320217] vdd-gen-pll-edp: 1050 mV
[ 0.324215] vdd-hdmi-dp: 1050 mV
[ 0.324814] max77620 4-003c: max77620 probe successful
[ 0.326630] media: Linux media interface: v0.10
[ 0.326699] Linux video capture interface: v2.00
[ 0.334029] tegra210-emc 7001b000.memory-controller: validated EMC DFS table
[ 0.334340] Advanced Linux Sound Architecture Driver Initialized.
[ 0.337630] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.337683] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.337770] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.337813] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.339885] regulator_get() failed for (dvfs,vdd-cpu), -19
[ 0.339910] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.344219] vdd-3v3: 3300 mV
[ 0.348215] max77620-gpio7: 1050 mV
[ 0.348514] lcd-bl-en: 1800 mV
[ 0.348828] en-vdd-sd: 3300 mV
[ 0.352216] vdd-sys-boost: 5000 mV
[ 0.352572] aux-3v3: 3300 mV
[ 0.352800] snsr_pm: 3300 mV
[ 0.356217] vdd-disp-3v0: 3000 mV
[ 0.356638] usb-vbus1: 5000 mV
[ 0.357544] rtl-5v0: 5000 mV
[ 0.357825] en-usb-vbus2: 5000 mV
[ 0.358211] en-vdd-vcm-2v8: 2800 mV
[ 0.360855] extcon-gpio-states extcon:extcon@1: Cable state 2
[ 0.362186] clocksource: Switched to clocksource arch_sys_counter
[ 0.402497] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.402863] dma_declare_coherent_resizable_cma_memory:290: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[ 0.403053] cma: enabled page replacement for spfn=c6000, epfn=f0000
[ 0.403081] dma_declare_coherent_resizable_cma_memory:337: resizable cma heap=vpr create successful
[ 0.403113] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.403176] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.403212] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.403534] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.404254] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[ 0.405019] pnp: PnP ACPI: disabled
[ 0.416464] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.418102] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.418545] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.418738] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.420210] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
[ 0.420457] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
[ 0.420676] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
[ 0.421857] isomgr_init(): iso emc max clk=1600000KHz
[ 0.421882] isomgr_init(): max_iso_bw=11520000KB
[ 0.422027] NET: Registered protocol family 2
[ 0.422630] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.422818] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.423069] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.423163] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.423226] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.423463] NET: Registered protocol family 1
[ 0.423777] RPC: Registered named UNIX socket transport module.
[ 0.423804] RPC: Registered udp transport module.
[ 0.423826] RPC: Registered tcp transport module.
[ 0.423846] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.424094] Trying to unpack rootfs image as initramfs...
[ 0.433957] host1x 50000000.host1x: initialized
[ 0.435687] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.438766] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.438905] audit: initializing netlink subsys (disabled)
[ 0.438968] audit: type=2000 audit(0.435:1): initialized
[ 0.450123] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.452868] io scheduler noop registered (default)
[ 0.452903] io scheduler deadline registered
[ 0.453216] io scheduler cfq registered
[ 0.458534] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 0.458582] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x9229410
[ 0.458618] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 0.459945] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 0.459980] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 0.460009] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 0.460045] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 0.460088] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 0.460122] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 0.460155] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 0.460196] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 0.460241] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 0.460288] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 0.460333] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 0.460378] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 0.460422] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 0.460470] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 0.460894] tegra21x-padctl-uphy 7009f000.pinctrl: mailbox is not ready yet
[ 0.461892] tegra-pwm 7000a000.pwm: PWM clk can sleep in ops
[ 0.462993] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.463689] Adding domain pcie-pd to PM domain mc-clk-pd
[ 0.467430] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.467497] tegra-pcie 1003000.pcie-controller: failed to get PHY: -517
[ 0.467524] tegra-pcie 1003000.pcie-controller: failed to get PHYs: -517
[ 0.470386] tsec 54500000.tsec: initialized
[ 0.471715] tsec 54100000.tsecb: initialized
[ 0.474144] nvdec 54480000.nvdec: initialized
[ 0.478823] falcon 54340000.vic: initialized
[ 0.480554] falcon 544c0000.nvenc: initialized
[ 0.481726] falcon 54380000.nvjpg: initialized
[ 0.483677] DC OR NODE connected to /host1x/dsi
[ 0.483769] display board info: id 0xffff, fab 0x0
[ 0.483854] display board info: id 0xffff, fab 0x0
[ 0.484034] parse_disp_default_out: No parent clk. dft clk will be used.
[ 0.484178] tegradc tegradc.0: DT parsed successfully
[ 0.484233] tegradc tegradc.0: Display dc.ffffff8000980000 registered with id=0
[ 0.484778] tegradc tegradc.0: DSI: HS clock rate is 445500
[ 0.485811] tegradc tegradc.0: probed
[ 0.486628] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.486841] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=4500000, max_bw=4687500
[ 0.490929] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.492925] tegra-adma 702e2000.adma: Tegra ADMA driver register 10 channels
[ 0.494477] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.494780] kfuse 7000fc00.kfuse: initialized
[ 0.496591] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.497544] clk_cbus_round_rate: no gbus parent
[ 0.497574] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 0.498079] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.498114] vdd-cpu: 708 <--> 1322 mV at 708 mV
[ 0.498208] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.499403] vdd-gpu: applied init 1000000uV constraint
[ 0.499433] vdd-gpu: 710 <--> 1320 mV at 1000 mV
[ 0.499499] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.499906] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.500051] No Device Node present for smmu client: serial8250 !!
[ 0.500080] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.500118] No Device Node present for smmu client: serial8250 !!
[ 0.500143] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.501213] No Device Node present for smmu client: serial8250 !!
[ 0.501243] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.501291] No Device Node present for smmu client: serial8250 !!
[ 0.501318] serial8250 serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.501968] console [ttyS0] disabled
[ 0.502044] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 320, base_baud = 25500000) is a Tegra
[ 2.492130] console [ttyS0] enabled
[ 2.493453] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 321, base_baud = 0) is a TEGRA_UART
[ 2.493899] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 322, base_baud = 0) is a TEGRA_UART
[ 2.494247] serial-tegra 70006300.serial: RX in PIO mode
[ 2.494343] 70006300.serial: ttyTHS3 at MMIO 0x70006300 (irq = 323, base_baud = 0) is a TEGRA_UART
[ 2.496626] gk20a 57000000.gpu: platform probe failed
[ 2.510028] brd: module loaded
[ 2.515215] loop: module loaded
[ 2.515767] Console: switching to colour frame buffer device 240x67
[ 2.515787] zram: Added device: zram0
[ 2.515800] Silicon Labs C2 port support v. 0.51.0 - (C) 2007 Rodolfo Giometti
[ 2.516015] nct1008_nct72 0-004c: find device tree node, parsing dt
[ 2.516021] nct1008_nct72 0-004c: starting parse dt
[ 2.516094] nct1008_nct72 0-004c: success parsing dt
[ 2.516297] nct1008_nct72 0-004c: success in enabling tmp451 VDD rail
[ 2.595497] tmp451: Enabled overheat logging at 102.00C
[ 2.595651] nct1008_nct72 0-004c: nct1008_probe: initialized
[ 2.636815] tegradc tegradc.0: fb registered
[ 2.642155] THERMAL EST: found 2 subdevs
[ 2.643479] tegradc tegradc.0: nominal-pclk:148500000 parent:148500000 div:1.0 pclk:148500000 147015000~161865000
[ 2.656654] THERMAL EST num_resources: 0
[ 2.660666] [THERMAL EST subdev 0]
[ 2.664147] [THERMAL EST subdev 1]
[ 2.667961] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.677083] THERMAL EST: thz register success.
[ 2.681764] THERMAL EST: end of probe, return err: 0
[ 2.686921] tegra_profiler: Branch: Dev
[ 2.690840] tegra_profiler: Version: 1.109
[ 2.695017] tegra_profiler: Samples version: 37
[ 2.699633] tegra_profiler: IO version: 21
[ 2.703813] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.708255] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.715343] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.719785] armv8_pmu: [1] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.726871] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.731313] armv8_pmu: [2] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.738399] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.742841] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0
[ 2.755456] tegra_profiler: auth: init
[ 2.765090] tegra-ahci 70027000.sata: Missing devslp-active state
[ 2.777631] Rounding down aligned max_sectors from 4294967295 to 4294967288
[ 2.790575] spi-tegra114 7000d400.spi: Static pin configuration used
[ 2.803949] spi-tegra114 7000da00.spi: Static pin configuration used
[ 2.807678] DC OR NODE connected to /host1x/sor1
[ 2.807928] tegradc tegradc.1: DT parsed successfully
[ 2.807972] tegradc tegradc.1: Display dc.ffffff8007380000 registered with id=1
[ 2.808289] hdmi: couldn't get regulator vdd_hdmi_5v0: -517
[ 2.810005] tegra-i2c 7000c700.i2c: no acknowledge from address 0x50
[ 2.811229] tegradc tegradc.1: probed
[ 2.881878] tun: Universal TUN/TAP device driver, 1.6
[ 2.892140] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.903546] tegradc tegradc.1: fb registered
[ 2.903998] PPP generic driver version 2.4.2
[ 2.904167] PPP BSD Compression module registered
[ 2.904174] PPP Deflate Compression module registered
[ 2.904195] PPP MPPE Compression module registered
[ 2.904206] NET: Registered protocol family 24
[ 2.904283] usbcore: registered new interface driver r8152
[ 2.904336] usbcore: registered new interface driver asix
[ 2.904378] usbcore: registered new interface driver ax88179_178a
[ 2.904425] usbcore: registered new interface driver cdc_ether
[ 2.904478] usbcore: registered new interface driver smsc95xx
[ 2.904518] usbcore: registered new interface driver net1080
[ 2.904557] usbcore: registered new interface driver cdc_subset
[ 2.904597] usbcore: registered new interface driver zaurus
[ 2.904667] usbcore: registered new interface driver cdc_ncm
[ 2.904785] usbcore: registered new interface driver usb-storage
[ 2.904875] usbcore: registered new interface driver usbserial
[ 2.904911] usbcore: registered new interface driver ftdi_sio
[ 2.904946] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.904986] usbcore: registered new interface driver option
[ 2.905014] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.905050] usbcore: registered new interface driver pl2303
[ 2.905078] usbserial: USB Serial support registered for pl2303
[ 2.906129] tegra-xudc-new 700d0000.xudc: usb2 phy is not available yet
[ 3.180217] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc1
[ 3.194213] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc0
[ 3.205759] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.216711] i2c /dev entries driver
[ 3.226600] IR NEC protocol handler initialized
[ 3.235473] IR Sharp protocol handler initialized
[ 3.244421] IR XMP protocol handler initialized
[ 3.253175] usbcore: registered new interface driver uvcvideo
[ 3.263102] USB Video Class driver (1.1.1)
[ 3.271693] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.284580] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.295859] tegra_soctherm 700e2000.soctherm: pllx_offset tz:1 max:8, min:4
[ 3.307476] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.321069] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.334329] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.347715] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.361415] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.374798] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.388291] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.402008] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature 2147483647 forced to 127000
[ 3.415514] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.428848] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.441378] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.454154] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.463942] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.473419] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.483944] FAN: coudln't get the regulator
[ 3.493278] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.506384] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.518966] device-mapper: uevent: version 1.0.3
[ 3.528198] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 3.544090] sdhci: Secure Digital Host Controller Interface driver
[ 3.554708] sdhci: Copyright(c) Pierre Ossman
[ 3.563414] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.574099] sdhci-tegra sdhci-tegra.3: Parent select= pll_p rate=408000000
[ 3.578345] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.578957] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.605126] sdhci-tegra sdhci-tegra.3: Parent select= pll_c4_out2 rate=199680000
[ 3.607595] usbcore: registered new interface driver usbhid
[ 3.607598] usbhid: USB HID core driver
[ 3.635374] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[ 3.647360] tegra-i2c 7000c400.i2c: no acknowledge from address 0x42
[ 3.658425] ina3221x 1-0042: ina3221 reset failure status: 0xffffff87
[ 3.669818] ina3221x: probe of 1-0042 failed with error -121
[ 3.680856] tegra-i2c 7000c400.i2c: no acknowledge from address 0x43
[ 3.690337] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[ 3.690669] sdhci-tegra sdhci-tegra.1: Parent select= pll_p rate=408000000
[ 3.690691] sdhci-tegra sdhci-tegra.1: Client registration for eMC Successful
[ 3.729845] ina3221x 1-0043: ina3221 reset failure status: 0xffffff87
[ 3.738281] mmc1: SDHCI controller on sdhci-tegra.1 [sdhci-tegra.1] using ADMA 64-bit with 64 bit addr
[ 3.738998] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.739048] sdhci-tegra sdhci-tegra.0: Got WP GPIO
[ 3.739124] sdhci-tegra sdhci-tegra.0: Parent select= pll_p rate=408000000
[ 3.739171] sdhci-tegra sdhci-tegra.0: wakeup init done, cd_irq: 262
[ 3.739193] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.741087] en-vdd-sd: supplied by vdd-3v3
[ 3.772722] mmc0: MAN_BKOPS_EN bit is not set
[ 3.775101] mmc2: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.779529] mmc0: Skipping tuning since strobe enabled
[ 3.785221] mmc0: new HS400 MMC card at address 0001
[ 3.785805] mmcblk0: mmc0:0001 016G32 14.7 GiB
[ 3.786066] mmcblk0rpmb: mmc0:0001 016G32 partition 3 4.00 MiB
[ 3.787664] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18
[ 3.831860] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.911928] ina3221x: probe of 1-0043 failed with error -121
[ 3.923673] parse_throttle_dt_data: Num cap clks = 6
[ 3.933971] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.944312] parse_throttle_dt_data: clk=gpu type=4
[ 3.954406] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.965775] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.977080] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.988189] parse_throttle_dt_data: clk=emc type=3
[ 3.998818] tegra_throttle_probe: probe successful. #cdevs=4
[ 4.009911] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[ 4.022458] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 4.033934] mmc1 tuning done saved tap delay=73
[ 4.033937] mmc1: hw tuning done ...
[ 4.033944] mmc1: tuning_window[0]: 0xfe7fffff
[ 4.033950] mmc1: tuning_window[1]: 0xfcffffff
[ 4.033955] mmc1: tuning_window[2]: 0xf3ffffff
[ 4.033960] mmc1: tuning_window[3]: 0x73ffffff
[ 4.033965] mmc1: tuning_window[4]: 0x0
[ 4.033970] mmc1: tuning_window[5]: 0x0
[ 4.033975] mmc1: tuning_window[6]: 0x0
[ 4.033979] mmc1: tuning_window[7]: 0x0
[ 4.033983] sdhci: Tap value: 73 | Trim value: 8
[ 4.033987] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 4.038964] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 4.039006] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.171561] tegra124-dfll 70110000.clock: config PMU interface as PWM
[ 4.185614] No Device Node present for smmu client: snd-soc-dummy !!
[ 4.196648] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 4.210939] No Device Node present for smmu client: snd-soc-dummy !!
[ 4.222286] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 4.225210] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 4.253330] No Device Node present for smmu client: snd-soc-dummy !!
[ 4.264506] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 4.279449] No Device Node present for smmu client: snd-soc-dummy !!
[ 4.290742] snd-soc-dummy snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 4.328085] tegra210-i2s tegra210-i2s.2: Missing prop fsync-width for I2S2
[ 4.344306] tegra210-i2s tegra210-i2s.3: Missing prop fsync-width for I2S3
[ 4.368902] OPE platform probe
[ 4.377092] OPE platform probe successful
[ 4.386334] OPE platform probe
[ 4.394366] OPE platform probe successful
[ 4.404018] GACT probability NOT on
[ 4.412220] Mirror/redirect action on
[ 4.420512] u32 classifier
[ 4.427721] Actions configured
[ 4.435634] Netfilter messages via NETLINK v0.30.
[ 4.448574] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[ 4.459519] ctnetlink v0.93: registering with nfnetlink.
[ 4.470054] xt_time: kernel timezone is -0000
[ 4.479021] ipip: IPv4 over IPv4 tunneling driver
[ 4.488793] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.498742] arp_tables: (C) 2002 David S. Miller
[ 4.507892] Initializing XFRM netlink socket
[ 4.517367] NET: Registered protocol family 10
[ 4.527368] mip6: Mobile IPv6
[ 4.534736] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.544648] sit: IPv6 over IPv4 tunneling driver
[ 4.558393] NET: Registered protocol family 17
[ 4.567201] NET: Registered protocol family 15
[ 4.575949] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.593075] Key type dns_resolver registered
[ 4.602831] Registered cp15_barrier emulation handler
[ 4.620691] isp 54600000.isp: initialized
[ 4.630807] isp 54680000.isp: initialized
[ 4.646871] clk_cbus_recalc_rate: no gbus parent
[ 4.655930] clk_cbus_round_rate: no gbus parent
[ 4.664876] clk_cbus_round_rate: no gbus parent
[ 4.673822] clk_cbus_recalc_rate: no gbus parent
[ 4.683466] clk_cbus_recalc_rate: no gbus parent
[ 4.692524] clk_cbus_round_rate: no gbus parent
[ 4.701441] clk_cbus_round_rate: no gbus parent
[ 4.710284] clk_cbus_recalc_rate: no gbus parent
[ 4.719207] tegra_dvfs: GPU-cap: registered
[ 4.727694] tegra dvfs: vdd-cpu: nominal 1226mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.740740] tegra dvfs: vdd-core: nominal 1125mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.753925] tegra dvfs: vdd-gpu: nominal 1120mV, offset 710000uV, step 10000uV, scaling enabled
[ 4.769454] tegra_dvfs: vdd-gpu-vts: registered
[ 4.782834] xhci-tegra 70090000.xusb: can't get usb3-0 phy (-517)
[ 4.794262] tegra21x-padctl-uphy 7009f000.pinctrl: padctl mmio start 0x000000007009f000 end 0x000000007009ffff
[ 4.809123] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_SKU_CALIB_0 0x9229410
[ 4.821651] tegra21x-padctl-uphy 7009f000.pinctrl: TEGRA_FUSE_USB_CALIB_EXT_0 0x4
[ 4.835316] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-0 is used by XUSB
[ 4.847026] tegra21x-padctl-uphy 7009f000.pinctrl: using UTMI port 0 for otg
[ 4.858991] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-2 is used by XUSB
[ 4.870682] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 5, set usb3_lanes = 0x20
[ 4.883595] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 1 maps to USB2 port 2
[ 4.896028] tegra21x-padctl-uphy 7009f000.pinctrl: UTMI-1 is used by XUSB
[ 4.907640] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 6, set usb3_lanes = 0x60
[ 4.920450] tegra21x-padctl-uphy 7009f000.pinctrl: USB3 port 0 maps to USB2 port 1
[ 4.932739] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 1, set pcie_lanes = 0x2
[ 4.945311] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 2, set pcie_lanes = 0x6
[ 4.957751] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 3, set pcie_lanes = 0xe
[ 4.970067] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 4, set pcie_lanes = 0x1e
[ 4.982376] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 0, set pcie_lanes = 0x1f
[ 4.994556] tegra21x-padctl-uphy 7009f000.pinctrl: uphy_lane = 7, set sata_lanes = 0x80
[ 5.007258] usb-vbus1: supplied by vdd-3v3
[ 5.017631] tegra21x-padctl-uphy 7009f000.pinctrl: Done tegra21x_padctl_uphy_probe
[ 5.031635] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 5.042418] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 5.053578] clk_cbus_round_rate: no gbus parent
[ 5.062327] tegra_gpu_edp gpu_edp: unable to get max GPU freq
[ 5.063405] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 5.065558] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 5.095296] tegra-ahci 70027000.sata: Missing devslp-active state
[ 5.096956] gk20a 57000000.gpu: GPCPLL initial settings: NA mode, M=1, N=34, P=3
[ 5.118861] tegra-ahci 70027000.sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 5.132289] tegra-ahci 70027000.sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 5.151146] scsi host0: tegra_ahci
[ 5.163294] scsi host1: tegra_ahci
[ 5.171203] ata1: SATA max UDMA/133 mmio [mem 0x70027000-0x70028fff] port 0x100 irq 371
[ 5.183589] ata2: DUMMY
[ 5.193396] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 5.204725] tegra-xudc-new 700d0000.xudc: entering ELPG
[ 5.215129] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[ 5.229039] tegra21x-padctl-uphy 7009f000.pinctrl: trying to assert IDDQ while XUSB partitions are on
[ 5.243250] tegra-xudc-new 700d0000.xudc: entering ELPG done
[ 5.244608] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[ 5.245005] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[ 5.245831] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[ 5.249286] xhci-tegra 70090000.xusb: UTMI port 0 has OTG_CAP
[ 5.249288] xhci-tegra 70090000.xusb: No USB3 port has OTG_CAP
[ 5.251995] xhci-tegra 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 5.251997] xhci-tegra 70090000.xusb: Falling back to user helper
[ 5.265958] input: gpio-keys as /devices/gpio-keys/input/input1
[ 5.287323] tegra_rtc 7000e000.rtc: setting system clock to 2000-01-01 01:03:19 UTC (946688599)
[ 5.288007] Disable partitions left on by BL
[ 5.288009] disb
[ 5.298154] DRAM derating cdev registered.
[ 5.298843] vdd-cpu-fixed: disabling
[ 5.298853] vdd-cam-hv: disabling
[ 5.298983] avdd-ts-hv: disabling
[ 5.299049] vdd-ts: disabling
[ 5.299113] max77620-gpio7: disabling
[ 5.299250] lcd-bl-en: disabling
[ 5.299254] en-vdd-sd: disabling
[ 5.299256] aux-3v3: disabling
[ 5.299258] snsr_pm: disabling
[ 5.299260] vdd-disp-3v0: disabling
[ 5.299262] usb-vbus1: disabling
[ 5.299264] rtl-5v0: disabling
[ 5.299265] en-usb-vbus2: disabling
[ 5.299267] en-vdd-vcm-2v8: disabling
[ 5.300106] ALSA device list:
[ 5.300109] #0: tegra-hda at 0x70038000 irq 349
[ 5.515405] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 5.522240] ata1: SATA link down (SStatus 0 SControl 300)
[ 5.531960] EXT4-fs (mmcblk0p1): couldn't mount as ext3 due to feature incompatibilities
[ 5.542836] EXT4-fs (mmcblk0p1): couldn't mount as ext2 due to feature incompatibilities
[ 5.966611] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 5.977749] EXT4-fs (mmcblk0p1): 10 orphan inodes deleted
[ 5.984962] EXT4-fs (mmcblk0p1): recovery complete
[ 5.998224] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 6.008114] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 6.017130] devtmpfs: mounted
[ 6.022289] Freeing unused kernel memory: 1200K (ffffffc001181000 - ffffffc0012ad000)
[ 6.032087] Freeing alternatives memory: 76K (ffffffc0012ad000 - ffffffc0012c0000)
[ 6.093081] systemd[1]: System time before build time, advancing clock.
[ 6.114432] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[ 6.127201] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.147656] systemd[1]: Detected architecture arm64.
[ 6.163732] systemd[1]: Set hostname to <localhost>.
[ 6.183326] random: systemd: uninitialized urandom read (16 bytes read, 92 bits of entropy available)
[ 6.196027] random: systemd: uninitialized urandom read (16 bytes read, 93 bits of entropy available)
[ 6.198667] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 93 bits of entropy available)
[ 6.200611] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 93 bits of entropy available)
[ 6.200683] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 93 bits of entropy available)
[ 6.200703] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 93 bits of entropy available)
[ 6.200818] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 93 bits of entropy available)
[ 6.206946] random: lvm2-activation: uninitialized urandom read (4 bytes read, 94 bits of entropy available)
[ 6.222507] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 95 bits of entropy available)
[ 6.417166] systemd[1]: Created slice System Slice.
[ 6.426622] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.428274] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 6.430218] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 6.453956] systemd[1]: Listening on Journal Audit Socket.
[ 6.463596] systemd[1]: Listening on udev Kernel Socket.
[ 6.476513] systemd[1]: Created slice User and Session Slice.
[ 6.486441] systemd[1]: Created slice system-getty.slice.
[ 6.495899] systemd[1]: Reached target Encrypted Volumes.
[ 6.505422] systemd[1]: Listening on LVM2 poll daemon socket.
[ 6.515382] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 6.526671] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 6.537185] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.547597] systemd[1]: Reached target User and Group Name Lookups.
[ 6.558529] systemd[1]: Listening on Journal Socket.
[ 6.570603] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.586065] systemd[1]: Mounting RPC Pipe File System...
[ 6.597442] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.611738] systemd[1]: Starting Load Kernel Modules...
[ 6.623417] systemd[1]: Started Braille Device Support.
[ 6.635780] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 6.647924] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 6.660000] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.674218] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 6.693557] systemd[1]: Listening on Syslog Socket.
[ 6.704659] systemd[1]: Starting Journal Service...
[ 6.715558] systemd[1]: Mounting Debug File System...
[ 6.726134] systemd[1]: Reached target Swap.
[ 6.735712] systemd[1]: Reached target Slices.
[ 6.745948] systemd[1]: Listening on udev Control Socket.
[ 6.758723] systemd[1]: Mounted RPC Pipe File System.
[ 6.769081] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.780298] systemd[1]: Mounted Debug File System.
[ 6.794072] systemd[1]: Started Remount Root and Kernel File Systems.
[ 6.805775] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
[ 6.817908] systemd[1]: Failed to start Load Kernel Modules.
[ 6.830230] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 6.840317] systemd[1]: systemd-modules-load.service: Unit entered failed state.
[ 6.850143] systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'.
[ 6.861232] systemd[1]: Started Create Static Device Nodes in /dev.
[ 6.873013] systemd[1]: Started Journal Service.
[ 6.956108] systemd-journald[221]: Received request to flush runtime journal from PID 1
[ 7.150199] random: nonblocking pool is initialized
[ 7.166467] cfg80211: World regulatory domain updated:
[ 7.166471] cfg80211: DFS Master region: unset
[ 7.166472] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.166475] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.166478] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.166479] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.166482] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.166484] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.166486] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 7.166488] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.166490] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 7.196253] xhci-tegra 70090000.xusb: cannot find firmware....retry after 1 second
[ 7.242188] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 7.668420] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 7.678283] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 7.686850] tegra-pcie 1003000.pcie-controller: PCIE: no end points detected
[ 7.696743] tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
[ 8.195832] xhci-tegra 70090000.xusb: Firmware timestamp: 2016-11-24 02:31:08 UTC, Version: 50.18 release
[ 8.216609] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 8.238162] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 1
[ 8.248652] xhci-tegra 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00010810
[ 8.259875] xhci-tegra 70090000.xusb: irq 319, io mem 0x70090000
[ 8.270695] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.280271] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.289833] usb usb1: Product: xHCI Host Controller
[ 8.296793] usb usb1: Manufacturer: Linux 4.4.38 xhci-hcd
[ 8.313948] usb usb1: SerialNumber: 70090000.xusb
[ 8.321311] hub 1-0:1.0: USB hub found
[ 8.327059] hub 1-0:1.0: 5 ports detected
[ 8.350257] xhci-tegra 70090000.xusb: xHCI Host Controller
[ 8.350267] xhci-tegra 70090000.xusb: new USB bus registered, assigned bus number 2
[ 8.350426] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.350430] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.350432] usb usb2: Product: xHCI Host Controller
[ 8.350435] usb usb2: Manufacturer: Linux 4.4.38 xhci-hcd
[ 8.350437] usb usb2: SerialNumber: 70090000.xusb
[ 8.350795] hub 2-0:1.0: USB hub found
[ 8.350822] hub 2-0:1.0: 4 ports detected
[ 8.646225] usb 1-1: new low-speed USB device number 2 using xhci-tegra
[ 8.662872] usb 2-1: new SuperSpeed USB device number 2 using xhci-tegra
[ 8.677007] usb 1-1: New USB device found, idVendor=046d, idProduct=c05a
[ 8.685626] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.694763] usb 1-1: Product: USB Optical Mouse
[ 8.701298] usb 1-1: Manufacturer: Logitech
[ 8.707782] usb 1-1: ep 0x81 - rounding interval to 64 microframes, ep desc says 80 microframes
[ 8.720843] usb 2-1: New USB device found, idVendor=0955, idProduct=09ff
[ 8.720846] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[ 8.720849] usb 2-1: Product: USB 10/100/1000 LAN
[ 8.720851] usb 2-1: Manufacturer: Nvidia
[ 8.720852] usb 2-1: SerialNumber: 000001000000
[ 8.724624] input: Logitech USB Optical Mouse as /devices/70090000.xusb/usb1/1-1/1-1:1.0/0003:046D:C05A.0001/input/input2
[ 8.724967] hid-generic 0003:046D:C05A.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-70090000.xusb-1/input0
[ 8.783283] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 8.790596] xhci-tegra 70090000.xusb: tegra_xhci_mbox_work mailbox command 6
[ 8.839365] usb 2-1: reset SuperSpeed USB device number 2 using xhci-tegra
Ubuntu 16.04 LTS localhost ttyS0
localhost login: nvidia (automatic login)
Last login: Fri May 6 05:40:14 UTC 2016 on ttyS0
[ 8.896901] r8152 2-1:1.0 eth0: v2.03.3 (2015/01/29)
[ 8.896904] r8152 2-1:1.0 eth0: This product is covered by one or more of the following patents:
[ 8.896904] US6,570,884, US6,115,776, and US6,327,625.
[ 8.896904]
Welcome to Ubuntu 16.04 LTS (GNU/Linux 4.4.38 aarch64)
* Documentation: https://help.ubuntu.com/
432 packages can be updated.
190 updates are security updates.
[ 9.049329] tegradc tegradc.0: nominal-pclk:3333000 parent:9998950 div:3.0 pclk:3332983 3299670~3632970
nvidia@localhost:~$
[ 9.661849] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 10.106441] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.139537] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
nvidia@localhost:~$
nvidia@localhost:~$
[ 12.624426] tegradc tegradc.0: nominal-pclk:3333000 parent:9998950 div:3.0 pclk:3332983 3299670~3632970
nvidia@localhost:~$
nvidia@localhost:~$
nvidia@localhost:~$ cd app_driver/bin/
[ 19.913645] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 21.885729] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
nvidia@localhost:~/app_driver/bin$ sudo ./interface_app
device.c: device_load: 85: dbg: dev: ADV7535 index 0 is loading...
adv7535.c: adv7535_init: 949: inf: adv7535_init++ line: 949
device.c: device_load: 110: inf: dev:ADV7535 index 0 Load successfully!
^C
[ 72.780478] nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
[ 78.307276] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
