I was looking at the maximum resolution the DSI interface can drive. Uncompressed the X1 datasheet says it’s 3480 x 1920 60Hz at 24bpp. That’s around 10Gbps so I assume that resolution must be done in ganged mode.
I was assuming you can drive 6Gbps (4 lanes x 1.5Gbps) per DSI for each DSI port but that max limit of 3480x1920 has me thinking it might be lower? My target is 1920x1200 at 60Hz 24bpp which is about 933MHz per lane 155MHz pixel clock. So the interface can do it but I’m concerned maybe there is another catch? I’ve read through the X1 documentation on it but it’s still not clear what the maximum pixel clock I can get out of one four lane DSI is.
Thank you
Hi eric,
Could you pls share that in which doc you see this “3480 x 1920 60Hz at 24bpp”?
What’s the meaning of ‘pixel clock’? Frequency of DSI clock lane should be the half of data rate of data lane, if data rate of each data lane is 933Mbps as you said, then the clock is 933/2Mhz, not 155Mhz.
Pixel clock is a common term in video that describes the constant rate at which pixels must flow so you get an entire frame of pixels in one refresh cycle. It’s also an easy way to understand the capability of a given video chip.
For example I need to transmit 2 streams one on each DSI interface. My resolution is 1920 x 1200 pixels at 24bpp. When you add in blanking that brings me to 2080 x 1249. My refresh rate is 60Hz (actually more accurately 59.87). So my pixel clock requirement would be 2080 * 1249 * 59.87 which is approximately 155.5MHz. So in order to keep up with my display I must deliver 24bits every 155.5Mhz which is approximately equal to 3.73Gbps.
This should run over the 6Gbps (4 lanes x 1.5Gbps) link but it is not clear to me from the documentation if the rest of the video pipeline can keep up with the full data rate or not. It’s also not clear to me if there might be some other limitation on maximum resolution or pixel clock for a single four lane DSI interface. In my case I need to run two 3.73Gbps streams, one on each DSI interface.
The “3480 x 1920 60Hz at 24bpp” comes from the “NVIDIA Tegra X1 Mobile Processor Technical Reference Manual” page 2144 Chapter 26: Display Interfaces: MIPI-DSI. Under features they show:
Maximum Video Mode resolution is
- Uncompressed: 3480x1920, 60 fps at 24 bpp
- Compressed: 4096x2304, 60 fps with 3:1 compression (8 bpp)
That appears to be in ganged mode so before I invest a lot of time and money into making some boards I wanted to check what the maximum resolution and pixel clock were for a single four lane DSI interface. Also I wanted to make sure there were not some other gotchas I didn’t understand.
Any update here? I’m stalled ready to start making some boards but I need to resolve this to move forward.
Thank you
Hi eric,
Yes, 3480 x 1920 60Hz at 24bpp is the max resolution in ganged mode. For single four lane DSI the max data rate is 6Gbps Maximum, 1.5Gbps per lane. Calculation of Pixel clock is this as you can see in chapter 26.5.8: pixel frequency = (TotalHorizontalPeriod * TotalVerticalPeriod * FrameRate) / 10^6
