dTPM 2.0 design for Jetson AGX Orin: Windows 11 IoT and Linux compatibility
Hi everyone,
I am designing a custom carrier board for the Jetson AGX Orin and need to integrate a dTPM 2.0 module to meet the following requirements:
  1. TPM 2.0 SPEC requirement。
  2. support both Windows 11 IoT Enterprise LTSC 64-bit
  3. Linux OS compliance。
Could you provide guidance on the hardware and firmware implementation for this dual-OS scenario? Specifically :
  • Interface & Configuration: Is there a preferred interface (SPI vs. I2C) that offers the best compatibility across both Windows and Linux on the Orin platform?
  • Driver/Firmware Considerations: Are there any critical considerations for the Device Tree (for Linux) or ACPI tables (for Windows) to ensure the TPM is correctly enumerated in both environments?
  • Recommended Parts: Are there specific TPM 2.0 chips (e.g., Infineon OPTIGA™ or Nuvoton NPCT series) that are known to work seamlessly with both Windows 11 IoT and the Jetson Linux driver stack?
Any advice on ensuring a smooth “out-of-the-box” experience for both OS environments would be greatly appreciated. Thanks!
hello eric.ch.chen,
we do not support dTPM for Jetson, yet.
please see-also developer guide, Firmware TPM for reference.
here’s see-also forum thread, Enable TPM on Jetson AGX orin
unfortunately, there’s no driver package or utilities to support that directly.
Hi Jerry,
Thank you for the clarification regarding dTPM support. I understand that NVIDIA currently does not provide official driver support for discrete TPMs on Jetson.
Given that my project requires Windows 11 IoT Enterprise LTSC compliance (which strictly requires TPM 2.0), I have two follow-up questions:
  1. fTPM Compatibility: Does the Jetson fTPM (via OP-TEE) satisfy the TPM 2.0 requirement for Windows 11 IoT Enterprise hardware certification?
  2. Custom dTPM Integration: If I choose to implement a dTPM on the carrier board, are there any specific technical hurdles (e.g., UEFI/ACPI limitations) that would prevent it from being recognized by Windows 11 IoT, even if I provide the necessary drivers?
Your guidance on how to best achieve Windows 11 IoT TPM compliance on Jetson would be highly appreciated."
hello eric.ch.chen,
according to your use-case, you should use an external dTPM device through I2C or SPI,
see-also developer guide, Jetson AGX Orin Platform Adaptation and Bring-Up.
you’ll need to have hardware platform change to support external dTPM.
you should able to use that with the open source TPM driver in the Linux kernel,
please evaluate the security feature whether it meets the requirement.
Hi Jerry,
Thank you for the clarification. I understand that I can integrate an external dTPM via SPI/I2C and utilize the open-source Linux kernel drivers.
To ensure a successful hardware integration, could you clarify:
  1. Device Tree Requirements: Are there any specific naming conventions or required properties in the Device Tree for the TPM node to be correctly probed by the tpm_tis_spi driver on the Orin platform?
  2. Interrupt/Reset Handling: Does the kernel driver require specific GPIO handling for the TPM’s interrupt and reset pins, or is it handled automatically by the TIS driver?
  3. Windows 11 Compatibility: While the Linux side is clear, for Windows 11 IoT, will the UEFI/BIOS firmware on the Orin expose the dTPM via ACPI tables automatically, or does this require custom UEFI firmware modification?
I will proceed with the SPI-based dTPM design as recommended.
thanks~
>> Q1
there’s no specific TPM node naming requirement.
please see-also.. tpm_tis_spi.txt.
for example,
        tpm_tis@0 {
                compatible = "tcg,tpm_tis-spi";
                spi-max-frequency = <10000000>;
>> Q2
the interrupt is optional. if no interrupt is described, tpm_tis_spi operates in polling mode.
if the TPM interrupt is connected, add the appropriate interrupt-parent and interrupts properties.
the generic tpm_tis_spi driver does not automatically control an external TPM reset GPIO.
>> Q3
this may requires a custom Windows BSP and UEFI implementation. please work with your Windows BSP provider, TPM vendor, and Microsoft certification channel before finalizing the carrier-board design.
Hi Jerry Chang,
"Thank you for the clear technical guidance. This clarifies the requirements for the SPI-based dTPM integration.
  1. Hardware Design: I will proceed with an SPI-based TPM 2.0 design (e.g., Infineon SLB 9670), ensuring dedicated GPIOs for both the Interrupt and Reset signals.
  2. Linux Implementation: I will follow the tpm_tis_spi standard and configure the Device Tree accordingly, utilizing the interrupt-driven mode for better performance.
  3. Windows/UEFI: I acknowledge that the Windows 11 IoT support requires custom UEFI/ACPI implementation. I will coordinate with a Windows BSP provider to ensure the TPM is correctly exposed in the ACPI tables.
This information is sufficient for me to finalize the carrier board design. Thank you for your support."
hello eric.ch.chen,
glad to know it helps, let’s close this forum discussion thread, you may start a new topic for further supports.
