I have peeling algorithm like this.
glDisable(GL_DEPTH_TEST);
glEnable(GL_BLEND);
glBindFramebuffer(GL_FRAMEBUFFER, dualDepthFBOID);
// Render targets 1 and 2 store the front and back colors
// Clear to 0.0 and use MAX blending to filter written color
// At most one front color and one back color can be written every pass
glDrawBuffers(2, &drawBuffers[1]);
glClearColor(0, 0, 0, 0);
glClear(GL_COLOR_BUFFER_BIT);
GL_CHECK_ERRORS
// Render target 0 stores (-minDepth, maxDepth, alphaMultiplier)
glDrawBuffer(drawBuffers[0]);
glClearColor(-MAX_DEPTH, -MAX_DEPTH, 0, 0);
glBlendEquation(GL_MAX);
DrawScene(MVP, initShader);
// 2. Depth peeling + blending pass
glDrawBuffer(drawBuffers[6]);
glClearColor(bg.x, bg.y, bg.z, bg.w);
int numLayers = (NUM_PASSES - 1) * 2;
int currId = 0;
for (int layer = 1; bUseOQ || layer < numLayers; layer++) {
currId = layer % 2;
int prevId = 1 - currId;
int bufId = currId * 3;
glDrawBuffers(2, &drawBuffers[bufId+1]);
glDrawBuffer(drawBuffers[bufId+0]);
// Render target 0: RG32F MAX blending
// Render target 1: RGBA MAX blending
// Render target 2: RGBA MAX blending
glDrawBuffers(3, &drawBuffers[bufId+0]);
glBlendFuncSeparate(GL_DST_ALPHA,GL_ONE,GL_ZERO,GL_ONE_MINUS_SRC_ALPHA);
glActiveTexture(GL_TEXTURE0);
glBindTexture(GL_TEXTURE_RECTANGLE, depthTexID[prevId]);
glActiveTexture(GL_TEXTURE1);
glBindTexture(GL_TEXTURE_RECTANGLE, texID[prevId]);
DrawScene(MVP, dualPeelShader, true,true);
// Full screen pass to alpha-blend the back color
glBlendEquation(GL_FUNC_ADD);
glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
if (bUseOQ) {
glBeginQuery(GL_SAMPLES_PASSED_ARB, queryId);
GL_CHECK_ERRORS
glBindTexture(GL_TEXTURE_RECTANGLE, backTexID[currId]);
blendShader.Use();
DrawFullScreenQuad();
blendShader.UnUse();
if (bUseOQ) {
glEndQuery(GL_SAMPLES_PASSED);
GLuint sample_count;
glGetQueryObjectuiv(queryId, GL_QUERY_RESULT, &sample_count);
if (sample_count == 0) {
break;
GL_CHECK_ERRORS
GL_CHECK_ERRORS
glDisable(GL_BLEND);
// 3. Final render pass
glBindFramebuffer(GL_FRAMEBUFFER, 0);
glDrawBuffer(GL_BACK_LEFT);
glBindTexture(GL_TEXTURE_RECTANGLE, colorBlenderTexID);
glBindTexture(GL_TEXTURE_RECTANGLE, depthTexID[currId]);
glBindTexture(GL_TEXTURE_RECTANGLE, texID[currId]);
glActiveTexture(GL_TEXTURE2);
finalShader.Use();
finalShader.UnUse();
So I tried glBlendFuncSeparate(GL_DST_ALPHA, GL_ONE, GL_ZERO, GL_ONE_MINUS_SRC_ALPHA) and that threw same result. I think, that this can add so much vertex colors, that it can result to extremly brighted color. Maybe I try change GL_ADD with GL_MAX
