Using Ubuntu 18.04 on a system with dual GPU (integrated ASpeed vga + Nvidia RTX 5000).
I am only able to see the desktop (and application windows) on one display, while the second display only shows the mouse cursor.
nvidia-smi
Sun Jan 3 15:59:09 2021
| NVIDIA-SMI 450.80.02 Driver Version: 450.80.02 CUDA Version: 11.0 |
| | | MIG M. |
| 0 Quadro RTX 5000 Off | 00000000:65:00.0 On | Off |
| 33% 29C P5 27W / 230W | 211MiB / 16125MiB | 22% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1497 G /usr/lib/xorg/Xorg 109MiB |
| 0 N/A N/A 15444 G /usr/bin/nvidia-settings 35MiB |
glxinfo |grep render
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
direct rendering: Yes
GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,
GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer,
Extended renderer info (GLX_MESA_query_renderer):
OpenGL renderer string: llvmpipe (LLVM 10.0.0, 256 bits)
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_MESA_ycbcr_texture, GL_NV_conditional_render, GL_NV_depth_clamp,
GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_fog_distance,
GL_EXT_polygon_offset_clamp, GL_EXT_read_format_bgra, GL_EXT_render_snorm,
GL_MESA_shader_integer_functions, GL_NV_conditional_render,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
OpenGL renderer string: Quadro RTX 5000/PCIe/SSE2
GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop,
GL_NV_compute_shader_derivatives, GL_NV_conditional_render,
GL_NV_parameter_buffer_object2, GL_NV_path_rendering,
GL_NV_path_rendering_shared_edge, GL_NV_pixel_data_range,
GL_NV_stereo_view_rendering, GL_NV_texgen_reflection,
GL_ARB_compute_variable_group_size, GL_ARB_conditional_render_inverted,
GL_EXT_multisample_compatibility, GL_EXT_multisampled_render_to_texture,
GL_EXT_multisampled_render_to_texture2,
GL_EXT_raster_multisample, GL_EXT_render_snorm, GL_EXT_robustness,
GL_NV_conditional_render, GL_NV_conservative_raster,
GL_NV_packed_float_linear, GL_NV_path_rendering,
GL_NV_path_rendering_shared_edge, GL_NV_pixel_buffer_object,
GL_NV_shadow_samplers_cube, GL_NV_stereo_view_rendering,
GL_OVR_multiview_multisampled_render_to_texture
sudo lshw -c video
*-display
description: VGA compatible controller
product: ASPEED Graphics Family
vendor: ASPEED Technology, Inc.
physical id: 0
bus info: pci@0000:05:00.0
version: 41
width: 32 bits
clock: 33MHz
capabilities: pm msi vga_controller bus_master cap_list rom
configuration: driver=ast latency=0
resources: irq:18 memory:a4000000-a7ffffff memory:a8000000-a801ffff ioport:2000(size=128) memory:c0000-dffff
*-display
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:65:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: iomemory:102f0-102ef iomemory:102f0-102ef irq:71 memory:df000000-dfffffff memory:102fe0000000-102fefffffff memory:102ff0000000-102ff1ffffff ioport:b000(size=128) memory:e0000000-e007ffff
