I have a weird issue with my monitor setup: All displays, besides the primary, have a weird offset. They are horizontally split, and the top of my screen is in the lower part of my monitor while the lower part is in the upper part. See here(https://imgur.com/a/OmSrAo6).
My hardware configuration:
- 2x NVIDIA GeForce RTX 2080 Ti Rev. A
- 3x Seasonic ELite 1440p Monitors (all connected to the first GPU)
My Software Setup:
- OS: Arch Linux
- WM: Qtile
- Driver: Nvidia-dkms
- Kernel: 5.10.6.arch1-1
This issue occurs only with the Nvidia (regardless if nvidia or nvidia-dkms) driver. While running the stock driver, everything shows up fine.
I suspected an issue in my Xorg configurations (see here), but neither nvidia-settings did the trick, nor another distro (Linux Mint). As soon as I installed the Nvidia driver (v460), the same issue occurs. So the problem seems to be specific to my setup. It’s either the dual GPU setup or the 2080 Ti causing problems. I have a second system with a 2080 Super, all three monitors attached via DP to it, and there are no issues so far.
Best,
Sandro
