Hardware:
- Jetson Orin Nano Super devkit
- L4T R36.5.0 (JetPack 6.2), BOARD: generic
- 2x generic (non-Jetson-certified) IMX219 modules, RaspberryPi-Camera-V2-clone style
- Confirmed 3.3-3.4V present on both camera boards (multimeter, steady-state)
Setup: jetson-io.py → Configure Jetson 22pin CSI Connector → “Camera IMX219 Dual”, overlay tegra234-p3767-camera-p3768-imx219-dual.dtbo.
Symptom (100% reproducible across many reboots):
[ 9.xxx] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 9.xxx] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 9.xxx] imx219 9-0010: board setup failed
[ 9.xxx] imx219: probe of 9-0010 failed with error -121
[ 9.xxx] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 9.xxx] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx219 10-0010 bound
Bus 9 (i2c-2 mux channel 0) always fails. Bus 10 (channel 1) always binds.
What I’ve ruled out, with direct evidence:
- Power — multimeter confirms 3.3-3.4V steady-state on both.
- Boot-timing race — identical failure across multiple independent reboots; also manually re-probed via sysfs unbind/bind ~4 minutes post-boot — same error.
- Connector/cable seating — checked/reseated multiple times.
- reset-gpios polarity — CAM0’s reset-gpios (GPIO 62, active-high) flipped to active-low, recompiled, reflashed: zero change.
- mux-gpios polarity — the shared cam_i2cmux select GPIO (GPIO 19) flipped: broke BOTH cameras (previously-good bus 10 also failed). Reverted. Confirms this GPIO matters but isn’t a simple invert.
- “OVERLAYS silently ignored on Super” bug (per this thread) — manually merged the overlay via
fdtoverlayinto the base dtb, pointed FDT directly at it: identical result, rules this out for my board. - GPIO ownership (
gpioinfo) — only CAM0’s reset-gpios shows as claimed; no conflicting claims found. - clocks/clock-names — no explicit binding exists in the overlay to check; MCLK is handled implicitly by the VI/CSI framework.
Note: the fault appears to follow the physical port/channel (bus 9 / i2c@0), not a specific camera unit, based on swap testing — though not tested exhaustively enough to be fully conclusive.
Question: is this a known compatibility issue between generic/clone IMX219 modules and channel 0 of the reference cam_i2cmux design on Orin Nano Super specifically? Or is there a device-tree property beyond reset-gpios/mux-gpios/clocks I haven’t checked? Happy to share the full decompiled .dtbo.
