I recently upgraded from Fedora 18 to 19 and now it appears that I cannot get my displays set up the way I used to without manually running nvidia-settings.
To describe my setup:
I have a Dell 2408 1920x1200 display on the right, connected via DVI to a GT 610.
On the left is a Dell U2410 1920x1200 display, connected via HDMI to the same GT610.
Under Fedora 18 (I don’t remember the Xorg or akmod NVIDIA versions), the right panel was “primary” and contained my Gnome3-in-fallback menu and window bars, and I could scroll left across the screen from the 2408 to the U2410.
Now, under Fedora 19, the Dell 2408 (on the right), is still my primary display, but when I try to scroll left onto the U2410, I hit the edge of the screen. X thinks the monitor physically on the left is on the right, and I have to scroll my mouse off the right edge of my primary display to get to it.
If I run nvidia-settings and choose Position:RightOf for the 2408, then things are good for that session only, despite having saved the configuration produced by nvidia-settings to /etc/X11/xorg.conf.
Here is my xorg.conf produced by nvidia-xconfig and then updated by nvidia-settings:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 325.15 (buildmeister@swio-display-x64-rhel04-03) Wed Jul 31 19:04:13 PDT 2013
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 325.15 (buildmeister@swio-display-x64-rhel04-03) Wed Jul 31 19:04:27 PDT 2013
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
FontPath "/usr/share/fonts/default/Type1"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "DELL 2408WFP"
HorizSync 30.0 - 83.0
VertRefresh 56.0 - 76.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GT 610"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-0"
Option "metamodes" "DVI-I-1: nvidia-auto-select +1920+0, HDMI-0: nvidia-auto-select +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
I’ve tried inserting MetaModeOrientation (and TwinViewOrientation just for the sake of it) with “DFP-0 RightOf DFP-1”, in the Screen section, tried it with DFP-1 LeftOf DFP-0, tried reversing DFP-0 and DFP-1 around, all to no avail. Running nvidia-settings and writing out the /etc/X11/xorg.conf used to “just work”, but that no longer is the case.
Anything completely obvious that I am missing?
Thank you.
