Dual solution Audio and a Power light indicator
I was a little frustrated with no power light, network light or anything besides heat to know the DGX Spark is up.
So I found a multi-function solution: Creative Pebble V3 Minimalistic 2.0 USB-C Speakers with Bluetooth® 5.0 - Creative Labs (United States)
  1. It’s USB power only, so if the blue power light is off, its down.
  2. USB-c audio connection is Plug & Play detected and works well from GNOME and with OpenClaw TTS…
  3. it is like it was made to match the DGX founder editions perfectly, matching in exact colors and accents in color :-)
Nice,
a) Can the second speaker be disconnected as well, or are they permanently connected?
b) At first, I used an old USB flash drive (with an LED)
c) Now I’m using a KVM (since it’s connected via USB, I’m only using 50% of its capacity). I got it primarily to address the Wi-Fi disconnections with the Spark; since I started using it, I haven’t had any disconnections—probably because using the HDMI port solved the problem—essentially acting as a more expensive HDMI dongle. However, the KVM has the advantage that you can join the same session, which otherwise requires workarounds in Windows 11 …
They are attached, but at $50, you can cut and tape up the ends, one with power to test just one…
One of these is $5 - Amazon.com: FSTURIOS USB Type C LED Ambient Light, 8 Colors RGB 5V Car Smart LED Atmosphere Lighting Night Lamp, Mini USB Adjustable Brightness Interior Light Decor for Home Car Laptop (2PCS) : Automotive
