Are both antenna connectors needed for Bluetooth and WIFI to work?
Is there any difference in function between the two?
If I only connect one antenna to my TX1 module how much wireless signal strength will be lost (ballpark)?
If you want both Bluetooth and WiFi to function, both antennas are required. With only one antenna connected, Bluetooth will drop out.
HI,
I need a clarification here.
Do you mean to say that if single antenna used, both function (WiFi and Bluetooth) will not be available simultaneously or only wifi available at any time? Bluetooth will be never available, if single antenna used?
Regards,
Ibram
Is there any update for me?
Hi Ibram,
We have provided the guidelines for customer to reuse NVIDIA wireless certificates for their products that implement Jetson TX1 module, please refer to :
[url]https://developer.nvidia.com/embedded/dlc/Jetson-TX1-OEM-Wireless-Compliance-Guide[/url]
