Dupkg_only_install_template template usage
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
Hi!
I am currently working on generating packages with the dupkg tool found on: drive/drive-foundation/tools/driveupdate/dupkg.
I am trying to generate a package with the template: dupkg_only_install_template. As you can notice, the template receives the following parameters:
dupkg lsin --template dupkg_only_install_template
# Output
DRIVE Update Packaging Tool
Version 1.4.6
List of all the variables that need to be provided as input while generating packages:
 Input Variable       | Req / Opt   | Description
 TEGRA_A_SRC          | Required    | Path to folder containing Tegra images, filesToFlash.txt
 VALIDATE_OPTION      | Optional    | If enable validate command [True | False]
 ERASE_PADDING_FLAG   | Optional    | If enable erase padding [0 | 1]
 AUTHENTICATOR_OPTION | Optional    | Set "AuthPkg" if enable Authenticator, Default is NormalPkg
 PRIVATE_KEY_PATH     | Optional    | The path to private key file. Required if enable Authenticator
 TEGRASIGN_PATH       | Optional    | The path to the tegrasign_v3.py tool in the PDK. Required if enable Authenticator and use HSM
 SHA_ALG              | Optional    | The SHA algorithm using for validation. Default is SHA256
 CHAIN                | Optional    | TA chain option for update, optional: A/B. Default is empty
 DISCARD_EMMC_FLAG    | Optional    | If erase the emmc chain [True | False]
 INSTALL_BRBCT        | Optional    | If install brbct [True | False]
 OS_VERSION           | Optional    | The OS version of images to generate DU package. Default is 6.0.8.0
I don’t know how should I get/create the filesToFlash.txt file. Does anyone know how I can I get this work?
Dear @ricardo.gonzalez1,
Just want to confirm if you are using PDK? I see DRIVE update is not included in sdk.
create_bsp_images.py generates the file.
Hi @SivaRamaKrishnaNV , actually we are using SDK. We asked for PDK permissions a couple of days ago and we don’t have progress on it.
Is there a way we can get this done?
DRIVE Update is not supported on DRIVE OS SDK.
