Duplicate pwr button on Jetson AGX Xavier DC
Good day!
How can i duplicate pwr/reset/forcerecovery buttons?
Have to use J508?
But after I used pins 1-2 together and pins 3-4 together, new reset and forcerecovery buttons didn’t work(standart res/forrec buttons work right). And I can use only new pwr button and only for start system.
hello a.katkov1991,
could you please also share more details about your actual use-case.
thanks
I use Jetson AGX Xavier Developer Kit with JetPack 4.3 and ubuntu 20.04
How can I duplicate buttons on the custom front panel?
The
Custom panel
hello a.katkov1991,
please check Jetson AGX Xavier Developer Kit Carrier Board Specification,
you may refer to [Table 3-7. Automation Header Description] for using 8-pin header, J508.
thanks
Which pin should I tie together to duplicate the power button, reset button, and full restore button?
please check Table 3-7, there’s pin number for the usage.
