consider this test code
subroutine foo_bar()
end subroutine
module foo
public :: bar
contains
subroutine bar()
end subroutine
end module foo
program test
use foo, only : bar
call bar();
call foo_bar();
end program test
It fails with the following error message
error: /home/cweiss/build/pgi_sdk/Linux_x86_64/22.3/compilers/share/llvm/bin/llc: /tmp/nvfortranZnaBzbR8MXno.ll:16:23: error: invalid redefinition of function 'foo_bar_'
The issue is that the function bar
inside the module foo
gets registered in the symbol table as foo_bar
. This is the same name which is used for the subroutine outside of the module. I cannot see a reason why this code might be invalid according to the Fortran standard.
As a side note, gfortran compiles this code. The module-associated function is called foo_MOD_bar
, which separates it from foo_bar
Best regards,
Christian
Hi Christian,
I can talk to our managers but it’s unlikely that we would change how we do the module function naming. It’s how we’ve always done this naming as far back as the initial PGI F90 implementation in the early 1990s. Perhaps they could have had more forethought, but changing the naming convention now would break compatibility and be extremely disruptive to our users.
Also, it’s extremely rare that anyone to encounter this issue (most folks don’t mix F77 and F90 style APIs), and is very easy to work around (either change the name or use BIND(C) to change the underlying symbol name), this is why I doubt they’ll want to make this change without a compelling reason.
-Mat
After playing around with this symbol name collision a little bit I found out that it is not related to mixed F77 and F90 APIs. Even if everything is F90 as in the following code, the problem remains:
MODULE foo
PUBLIC :: foo_bar
CONTAINS
SUBROUTINE foo_bar()
END SUBROUTINE
END MODULE foo
MODULE foo_foo
PUBLIC :: bar
CONTAINS
SUBROUTINE bar()
END SUBROUTINE bar
END MODULE foo_foo
PROGRAM test
USE foo, ONLY : foo_bar
USE foo_foo, ONLY: bar
CALL foo_bar()
CALL bar()
END PROGRAM test
Hi Mat,
thanks for the quick reply. I understand that fixing this issue is very involved and has a low priority. I just wanted to point it out, in case that you might find it interesting. For me, it’s not an important issue that needs resolution.
Best regards,
Christian
