(dusty-nv/jetson-inference) Accessing labels
I am following the tutorials for Jetson Nano Dev on github (dusty-nv/jetson-inference).
Things are working as expected, but I couldn’t figure out how to extract labels/class id. Based on what I can see from these sites -
I think it should be doable, but I can’t seem to figure it out. Do I have to download the label file (or make a list) and import and use that? Also, when I tried accessing ClassID inside of detectNet.Detection Object - by doing this -
detections = net.Detect(input_image, rgb.shape[1], rgb.shape[0])
for detection in detections:
     print(detection.ClassID)
It didn’t work for me… Its output was 70. If someone could please point me in the right direction, I would appreciate it.
Thanks,
Jae
ClassID can be found in the c++ interface here:
Hi AastaLLL
By any chance you have the same information for Python?
Jae
Hi @a428tm, please see this post: Using detectNet to get coordinates of an object detected by camera
The Python detectNet.Detection object has similar members that you can access the ClassID and bounding box coordinates through.
