Hi All,
I am working with
- Multicore System with 64bit RHEL 4.5 linux as OS
- Nvidia GTX-8800 Graphic Card
- DVS Capture Card
My capture card is capturing NTSC Video at 30fps.
As soon as I enable CUDAMallocHost to allocate memory on host, in my capture card’s program the program starts giving a FRAME LOSS!!!.
I disabled IRQBALANCE service but things didnt work…
Any guidance will be appreciable.
Samir Bhatt
Just to be sure -
what happens if you do CudaMallocHost first, and then start the capture program?
(I suspect that the DMA interaction between the CUDA GPU and the capture card is causing this - but I don’t know.)
Firstly Thanks for the response, yes It is already done first.
To brief you more, following is the code skeleton
CudaMallocHost is the first initialization in the code
Initialize the capture
Spawn capture thread
Spawn Processing Thread.
Get the results…
