Dear SivaRamaKrishna.
I tried the parameters that you instructed, but failed to start with the DW_SAL_CANNOT_INITIALIZE error.
Our lidar uses an IP address of 192.168.1.201 and a port number of 2368. Therefore I think that connection is failing.
Please let me make a correction. The error when specifying VELO_HDL32E was DW_FAILURE.
device=VELO_HDL32E,ip=192.168.1.211,port=2211,scan-frequency=10
[24-07-2019 09:12:29] Platform: Detected DDPX - Tegra A
[24-07-2019 09:12:29] Initialize DriveWorks SDK v2.0.2081
[24-07-2019 09:12:29] Release build with GNU 4.9.4 from heads/buildbrain-branch-0-g36b127f against Drive PDK v5.1.0.2
[24-07-2019 09:12:29] TimeSource: monotonic epoch time offset is 1563926534295583
[24-07-2019 09:12:29] PTP Time is available from NVPPS Driver
[24-07-2019 09:12:29] Platform: number of GPU devices detected 2
[24-07-2019 09:12:29] Platform: currently selected GPU device discrete ID 0
[24-07-2019 09:12:29] SDK: Resources mounted from /usr/local/driveworks-2.0/data/
[24-07-2019 09:12:29] SDK: Create NvMediaDevice
[24-07-2019 09:12:29] egl::Display: found 2 EGL devices
[24-07-2019 09:12:29] egl::Display: use drm device: drm-nvdc
[24-07-2019 09:12:29] Platform: currently selected GPU device integrated ID 1
[24-07-2019 09:12:29] Loading rig file: lexus_lidar/nvidia_forum.json
[24-07-2019 09:12:29] SensorFactory::createSensor() -> lidar.socket, device=VELO_HDL32E,ip=192.168.1.211,port=2211,scan-frequency=10
[24-07-2019 09:12:29] Destination IP address and Horizontal Resolution is used only by OUSTER Lidar
Return Mode is used only by Velodyne Lidar
[24-07-2019 09:12:44] SensorManager: DW_SAL_CANNOT_INITIALIZE: LidarSocket::checkDeviceData, 192.168.1.211:2211 is not connected
[24-07-2019 09:12:44] SensorManager: Failed to add sensor from rig: lidar.socket device=VELO_HDL32E,ip=192.168.1.211,port=2211,scan-frequency=10 (Error: DW_SAL_CANNOT_INITIALIZE)
terminate called after throwing an instance of 'dw::core::Exception'
what(): DW_SAL_CANNOT_INITIALIZE: SensorManager: Failed to add sensors from rig
Aborted (core dumped)
device=VELO_HDL32E,ip=192.168.1.201,port=2368,scan-frequency=10
[24-07-2019 10:23:39] Platform: Detected DDPX - Tegra A
[24-07-2019 10:23:39] Initialize DriveWorks SDK v2.0.2081
[24-07-2019 10:23:39] Release build with GNU 4.9.4 from heads/buildbrain-branch-0-g36b127f against Drive PDK v5.1.0.2
[24-07-2019 10:23:39] TimeSource: monotonic epoch time offset is 1563926534295583
[24-07-2019 10:23:39] PTP Time is available from NVPPS Driver
[24-07-2019 10:23:39] Platform: number of GPU devices detected 2
[24-07-2019 10:23:39] Platform: currently selected GPU device discrete ID 0
[24-07-2019 10:23:39] SDK: Resources mounted from /usr/local/driveworks-2.0/data/
[24-07-2019 10:23:39] SDK: Create NvMediaDevice
[24-07-2019 10:23:39] egl::Display: found 2 EGL devices
[24-07-2019 10:23:39] egl::Display: use drm device: drm-nvdc
[24-07-2019 10:23:39] Platform: currently selected GPU device integrated ID 1
[24-07-2019 10:23:39] Loading rig file: lexus_lidar/192.168.1.200_error.json
[24-07-2019 10:23:39] SensorFactory::createSensor() -> lidar.socket, device=VELO_HDL32E,ip=192.168.1.201,port=2368,scan-frequency=10,protocol=udp
[24-07-2019 10:23:39] Destination IP address and Horizontal Resolution is used only by OUSTER Lidar
[24-07-2019 10:23:39] SensorManager: DW_FAILURE: DecoderVelodyne::processStatus, device type does not match product ID 0x21
[24-07-2019 10:23:39] SensorManager: Failed to add sensor from rig: lidar.socket device=VELO_HDL32E,ip=192.168.1.201,port=2368,scan-frequency=10,protocol=udp (Error: DW_FAILURE)
what(): DW_FAILURE: SensorManager: Failed to add sensors from rig
device=VELO_VLP16HR,ip=192.168.1.201,port=2368,scan-frequency=10
[24-07-2019 09:15:53] Platform: Detected DDPX - Tegra A
[24-07-2019 09:15:53] Initialize DriveWorks SDK v2.0.2081
[24-07-2019 09:15:53] Release build with GNU 4.9.4 from heads/buildbrain-branch-0-g36b127f against Drive PDK v5.1.0.2
[24-07-2019 09:15:53] TimeSource: monotonic epoch time offset is 1563926534295583
[24-07-2019 09:15:53] PTP Time is available from NVPPS Driver
[24-07-2019 09:15:54] Platform: number of GPU devices detected 2
[24-07-2019 09:15:54] Platform: currently selected GPU device discrete ID 0
[24-07-2019 09:15:54] SDK: Resources mounted from /usr/local/driveworks-2.0/data/
[24-07-2019 09:15:54] SDK: Create NvMediaDevice
[24-07-2019 09:15:54] egl::Display: found 2 EGL devices
[24-07-2019 09:15:54] egl::Display: use drm device: drm-nvdc
[24-07-2019 09:15:54] Platform: currently selected GPU device integrated ID 1
[24-07-2019 09:15:54] Loading rig file: lexus_lidar/192.168.1.200.json
[24-07-2019 09:15:54] SensorFactory::createSensor() -> lidar.socket, device=VELO_VLP16HR,ip=192.168.1.201,port=2368,scan-frequency=10,protocol=udp
[24-07-2019 09:15:54] Destination IP address and Horizontal Resolution is used only by OUSTER Lidar
[24-07-2019 09:15:54] DecoderVelodyne : Changing return mode to STRONGEST
[24-07-2019 09:15:54] LidarSocket::LidarSocket, connected to 192.168.1.201:2368
Rig: 192.168.1.200.json NewSink: /dev/null
[24-07-2019 09:15:54] SensorManager: started
Press s<Enter> to start, just <Enter> to see progress, q<Enter> to quit.
