Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I’m trying to extract lraw data with DW3.5 and SDK 1.8.1 version and my CUDA version is 10.2. The extractor is similar to bin2pcd extraction and ts extraction, and these are working (so probably installations are ok) but lraw2png is not working. I couldn’t find that much information and the root cause of the problem online. Any suggestions about the error?
I forgot to add a few details about the problem. These lraw recordings are made with DW3.5 and I do the extraction offline on a different machine. The data I am trying to extract is test data and I was able to extract it with dw3.5 before. I changed my code and installed dw3.5, sdk, and cuda in a dockerfile. As the base image, I’m using cuda 10.2, and I am trying to perform extraction in the docker container.
Also you can find driveworks related part of my dockerfile below:
COPY sdkmanager_1.8.1-10392_amd64.deb /app
RUN apt-get install -y /app/sdkmanager_1.8.1-10392_amd64.deb
RUN dpkg -i /app/driveworks-v3.5.75_24268780_20201103_c61a9a35bd0_nopdkgcid_linux-amd64-ubuntu.deb
RUN dpkg -i /app/driveworks_cross_linux-v3.5.75_24268780_20201103_c61a9a35bd0_22871222_drive-linux-5.2.0.0.deb
RUN dpkg -i /app/driveworks_data-v3.5.75_24268780_20201103_c61a9a35bd0_nopdkgcid_linux-amd64-ubuntu.deb
RUN dpkg -i /app/driveworks_samples-v3.5.75_24268780_20201103_c61a9a35bd0_nopdkgcid_linux-amd64-ubuntu.deb
Note:I changed some parts to make it clear what is installed.
Dear @ytangul1,
As I understand, you already have lraw recording recorded using DW 3.5. Did you perform lraw2png conversion(for test dataset) using some third party tool or using DW application? I don’t see any LRAW → png image conversion APIs/tool in DW.
I solved the issue, but now I have bigger problem. Its been 2 days I’m trying to login my nvidia account. I tried to login from different nvidia pages but still I can’t get a verification mail, this is causing delay of my work. I will be so glad if you can help with the issue.
Dear @ytangul1,
Could you please file a seperate topic with more details like where do you see issue in the pipeline? You can attach pictures for more clarify.
Do you notice issue when logging into sdkmanager/devzone as well?
