dwLogger callback error+question
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
While trying to log messages using the dwLogger as described in the documentation, I get this error:
error: too few arguments to function ‘void plotting_callback(dwContextHandle_t, dwLoggerVerbosity, const char*)’
505 | dwLogger_initialize(plotting_callback());
What is the correct syntax for setting a callback for the logger?
Additionally, what is contained in the ‘msg’ part of the dwLoggerMessage that the logger sends?
Dear @stefan65,
I notice the DW samples are using the call back functions(getConsoleLoggerCallback/getConsoleLoggerExtendedCallback) at samples/framework/Log.cpp . You may use it as reference to implement your logging function.
In your case, plotting_callback() is called with no parameters where as the function defined with 3 parameters.
The msg contains the actual message that needs to print to log.
Dear @stefan65,
Any update can be provided on this issue?
Could you check with dwLogger_initialize(plotting_callback) and confirm if it works?
It does not seem to work. According to the documentation in the Logging Tutorial, it is to be called with no arguments: DriveWorks SDK Reference: Logging
Could we get some updated documentation on this topic?
Dear @stefan65,
Could you tell what did not work? Is dwLogger_initialize(plotting_callback) did not help?
